08-30-2013, 01:28 AM | #1 |
NativeStreetMachine
Drives: 2013 Red 1LE Join Date: Oct 2009
1LE transmission fluid
Been trying to find a solid answer on which fluid to use. There are a lot of different answers that say to use ATF, some say not to. Is there something that someone can recommend?
08-30-2013, 01:31 AM | #2 |
ROAD COURSE JUNKIE
I used a GM fluid. Worked great and reduced the second gear grind and made shifting a lot smoother. I also did the rear diff. Here is what I used.
09-09-2013, 11:49 AM | #3 |
Drives: '13 1LE, '89 Caprice Join Date: Jul 2013
I believe it tells you to use ATF in the owner's manual.
09-09-2013, 04:25 PM | #4 |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Any GM dealer can print you off a spec sheet on what fluids the car calls for. I have it in my glove box. I'll try to look for it once I'm home from work.
09-09-2013, 04:44 PM | #5 |
I bought Mobil 1 synthetic ATF for the change that I will be doing tomorrow. It takes 4 qt.
09-12-2013, 04:57 PM | #6 |
Drives: 2010 2ss/rs & 2014 Stingray Join Date: Aug 2013
Redline D4 ATF, you will feel the difference.
09-12-2013, 05:06 PM | #7 |
09-12-2013, 08:33 PM | #8 |
Changed my trans 2 days ago with Mobil 1 syn ATF. I also did my diff with Mobil 1 syn 75W-90 w/slip additive. The car is shifting much better now.
I don't track the car, I just use it as a daily driver so Mobil 1 is good enough for me. I would like to do a track day eventually and might consider switching to something better for that (like Redline). |
09-18-2013, 05:42 PM | #9 |
Drives: ( . )( . ) Join Date: Feb 2010
i thought ATF stands for Automatic Transmission Fluid?
09-18-2013, 06:12 PM | #10 |
Drives: 2012 LS M6, Black Join Date: May 2009
It does, and ironically, it's also used in the manual box in the SS.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
09-18-2013, 06:26 PM | #11 |
Weird that they call it that. LOL.
I remember i changed my transmission fluid with Mobi1, but i dont remember it said ATF. this was on my LS though, so it might be different for the SS.
09-18-2013, 06:27 PM | #12 |
V-6 cars use 75W-90 gear lube, not ATF.
John B.
09-18-2013, 06:29 PM | #13 |
yes, thats exactly what i put in it.
09-18-2013, 06:34 PM | #14 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
I used Valvoline Maxlife ATF it's full synthetic with a bunch of additives. Been happy. Mobil 1 synthetic ATF is good too. The Redline synthetic ATF will work also.
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
