Rick@Livernois
Old 05-23-2018, 02:55 PM   #1
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
L99 build w/ GPI Max Package Results!!!&Track Times!!!!& E85
This car is set to hit the rollers again on Friday morning.
14 2SS with 35k bone stock right down to the air filter.
Baseline dyno numbers at GPI 339hp/344tq
This build has been a little bit of R&D on the VVT Max Package.
As far as I know the only Max Package that has not been built at GPI and the only L99 VVT on the street.
I told Aaron@GPI I wanted to be able to drive this car anywhere but I wanted it to run like a big cube motor with great throttle response.
Well here is what we ended up with. Lots of compression and lots of overlap
GPI MAX LS7 castings Milled to 11.5cr
VVT MAX 3 cam 233/252 112
Msd LS7 intake
Johnson lifters
Bo White PTB
Vararam CAI
Kooks 1 7/8" headers
Kooks full 3" catless Exhaust with a resonated Magnaflow muffler to kill the drone
Circle D 4c
391 gears
Udp
E85
I did the install and assembly, everything measured out exactly as Aaron said (this guy is sharp). This setup is as tight as you can get without flycutting. Ryan@GPI (Rhino79) built the start up tune to get the car up and running and back down to GPI for the final tune. Which I can't believe the job he did I have put a few hundred miles on this setup and all I can say is WOW! This car is still on the base tune but it is an animal! and drives really well. I was really concerned about the bottom end being flat with a setup that's all about rpms but I can tell you the bottom end and the midrange is crazy!! Some of you L99 guys have been waiting on these results for awhile well Friday is the day.
Baddbird is offline   Reply With Quote
Old 05-23-2018, 03:49 PM   #2
jergarr
jergarr's Avatar
Drives: 11' RJT 2SS/RS L99
Can't wait to see the results. Would have loved to have done this setup but did not have the $.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall
1LE 3.91s
Stainless Power Headers w/cats
Fluidampr 25% UDP
Cold Air Inductions Intake
Bo White Ported Throttle Body
ADM Trans Cooler
Some BMR Goodies
jergarr is offline   Reply With Quote
Old 05-23-2018, 04:12 PM   #3
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2014 Camaro 1SS RS SIM
Dream build right there, looking forward to the results!
2014 SS - L99 1SS/RS - "AleSSandra"
SSEssence is offline   Reply With Quote
Old 05-23-2018, 04:25 PM   #4
bkevind
Drives: 2013 2RSS 1LE
Is it Friday yet?
bkevind is offline   Reply With Quote
Old 05-23-2018, 05:01 PM   #5
shaggy2002
Drives: 2013 VR 2SS w RS 1LE
watching this thread as it is almost the same build I want. GPI Max Performance Package with Johnson Lifters. Kooks Headers, CAI intake. I have a 1LE so I have a 3.91 but I am swapping a 4L80E with converter. Good luck on the numbers!
shaggy2002 is offline   Reply With Quote
Old 05-23-2018, 06:57 PM   #6
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
Before 3" exhaust
Kooks No cats stock exhaust
Old 05-23-2018, 07:02 PM   #7
shaggy2002
Originally Posted by Baddbird View Post
Before 3" exhaust
Sounds good.....I got 1 7/8 kooks, kooks hi flow cats, going to the NPP. So mine will be slightly different.
Old 05-23-2018, 08:45 PM   #8
Arch-City
Drives: 2015 Camaro 1LE
VVT MAX 3 cam The specs are between arch-citys 232 cam and the rock crawlers 226 Will post up the cam specs after the dyno
Msd LS7 intake
Johnson lifters
Bo White PTB
Vararam CAI
Circle D 4c
391 gears
Udp
Nice build. You are going to love this set-up. And, man you are right Aaron is a sharp SOB. The guys at GPI have me sold on their builds. You are going to be really impressed with Ryan and his tuning. Can't wait to see those numbers, but even without them your ASS Dyno tells you what you got.
You will see my car when you are there Friday, we decided to go with a bigger cam now. So I will have to wait until the 8th or 9th to get her picked up.
Arch-City is offline   Reply With Quote
Old 05-24-2018, 07:40 AM   #9
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
That thing should make some steam!! Are you going to run it at the track?
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
10.16 @134mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 05-24-2018, 07:54 AM   #10
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
Yea. To be honest that is why I skipped the E85 on this setup for now. I figure the money would be better spent on suspension upgrades.
Old 05-24-2018, 08:57 AM   #11
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
+1 for GPI builds. Humbled an M3 last weekend. I warned him first...
Procharger D-1/Race Intercooler/GPI SS3 Cam/Kooks LTH/X- pipe/13 PSI Boost/ID 1050/E85 Conversion/3.91 gears/Flowmaster/ZL1 rims/MT ET R
-775whp/680tq https://www.youtube.com/watch?v=nW9lhSQNKTw
Taylortoons is offline   Reply With Quote
Old 05-25-2018, 10:32 AM   #12
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Following!
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-25-2018, 10:52 AM   #13
Royal Tiger
Sd Kfz 182
Royal Tiger's Avatar
Drives: 2013 2SS/RS L99 GFX Convertible
I should hope so with like 860hp.
CAI intake/American Racing LTH & HFC/Borla ATAK/MBRP tips/3.91 rear/Forgeline 20” GA3 wheels/Nitto Invos (275/40 & 315/35)/Koni yellows/BMR: springs, toe links, trailing arms, strut tower, subframe & tunnel braces, cradle & radius arm bushings, front & rear sway bars/R1 slotted & cross drilled rotors/Tuned by Fran@Race Proven Motorsports 387.74rwhp 412.09rwtq
Royal Tiger is offline   Reply With Quote
Old 05-25-2018, 02:27 PM   #14
jc615
jc615's Avatar
Drives: Camaro and Sierra
That's like saying I humbled a Mini Cooper last week lol
jc615 is offline   Reply With Quote
