Gen5DIY
Old 06-10-2018, 01:12 AM   #1
SergioSS
SergioSS's Avatar
Drives: Summet white , Camaro 2SS 2013
Camaro needs to sound louder and aggressive
Ok so I started off by putting on flowmaster super 10s it did make it louder but it wasnít the sound I was looking for so then I added kooks 1 7/8 lt headers with hfc and it didnít really make it louder only like at wot so then I got a summit racing xpipe and it did help make it louder and a lot deeper , Iím still not really satisfied I should have better off went with the off road cats Iím debating either doing a muffler delete and seeing how that sounds or get kooks off road
2013 Camaro SS , Kooks lt header hfc , xpipe , flowmaster super 10, ported tb , tune by Steve
SergioSS is offline   Reply With Quote
Old 06-10-2018, 01:43 AM   #2
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
Get a cam and heads and cut outs
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2005 silverado 5.3
Long tubes, true dual bullets, aem intake , synergy tuned
2001 trans am
Lsx 408 ci rebuild in progress
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 06-10-2018, 07:59 AM   #3
SergioSS
SergioSS's Avatar
Oh man how that would sound so awesome ! 😍
Old 06-10-2018, 10:21 AM   #4
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #830
Why not some Noweeds diverters or cutouts? That way you can be legal when you need to be but loud as hell when you want to be.
'10 Camaro 2SS/RS | Aqua Blue #830 of 3,903 | Silver Stripes
Check out my build thread
Old 06-10-2018, 06:03 PM   #5
SergioSS
SergioSS's Avatar
Thatís a good idea I might go with that ! Thanks lol and noweeds ?
Old 06-10-2018, 06:56 PM   #6
STALKER
STALKER's Avatar
Drives: 2014 Camaro SS Spring Edition
I'd try deleting the cats first to see how you like that before doing anything else.
LSX440ci
LSX Bowtie Block, PRC 285 LS7 Heads w/ Ti Intake Valves, Diamond Pistons, Callies Compstar Crank & H-Beam Rods, Custom Comp Cam, LS7 Lifters & Pushrods, Trunion Modified LS7 Rockers, FAST LSXR Intake, NW 102 TB, Z28 CAI, FAST Fuel Rails & 65# Injectors, Kooks 1-7/8" Headers, Kooks Z28 3" X-Pipe & Cat-Back, Z28/1LE Shifter, ZR1 Clutch w/ Katech Lightweight Flywheel, BMR 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, and Tunnel Brace, Z28/1LE Strut Tower Brace, 20" Z28 Wheels with Nitto Rubber.
STALKER is offline   Reply With Quote
Old 06-10-2018, 07:15 PM   #7
pyroguy
pyroguy's Avatar
Drives: ABM #830
Google Noweeds. They're one of the most high quality diverter you can get. I've often thought about getting them for my car but it's loud enough for me for now. A cam will solve my desire to go louder later.
Old 06-10-2018, 11:51 PM   #8
SergioSS
SergioSS's Avatar
Iíve seen some camaros with electric cutouts really loud, but Iíve seen some close to the cats and some close to the mufflers which would be the best to install them
Old 06-11-2018, 12:27 AM   #9
BT96SS
Drives: 2012 Camaro RS/SS
Get muffler deletes. I just got header installed w high flow cats. I still have the factory resonator. Car has very deep sound. It too loud for me but I would be most members here would go nuts over the sound.
BT96SS is offline   Reply With Quote
Old 06-11-2018, 01:50 PM   #10
pyroguy
pyroguy's Avatar
Drives: ABM #830
https://noweeds.net/products/noweeds...-stock-exhaust
These install just past the cats. If I got just regular cutouts thatís where Iíd install them too. The point is to make the car louder so you want as little piping in between the engine and the exit as possible.
Old 06-11-2018, 02:15 PM   #11
SSkat
Drives: 2010 Camaro 2SS
What about the QTP system? i havent seen any reviews
SSkat is online now   Reply With Quote
Old 06-11-2018, 04:09 PM   #12
xc_SS/RS
Drives: 2010 Camaro SS/RS
just run dumps after the x-pipe/before the rear axle
2010 2SS/RS
Z/28 intake, ported TB, vr wedge, rod-mod intake, speed engineering LT's, 3" exhaust, ATI -10% pulley, MGW shifter, 160* t-stat, HP Tuners, some suspension work, stickers and a little weight loss. 12.72 @112.36 - improvements coming
xc_SS/RS is online now   Reply With Quote
Old 06-11-2018, 06:29 PM   #13
SergioSS
SergioSS's Avatar
Right I thought that would be the best place for them behind the cats , what kind would you recommend? Iíve found some on summit racing some custom .
Old 06-11-2018, 06:44 PM   #14
SergioSS
SergioSS's Avatar
I also see the qtp oval cutouts on phasket performance
