Old 06-10-2018, 11:33 PM   #1
tylerng1999
tylerng1999's Avatar
Drives: 2012 Camaro 1LS
NPP Exhaust Vacuum to Electric Conversion
Attempting to swap out the factory vacuum actuators on the NPP exhaust to a set of electric actuators found on eBay. Pics of the reverse polarity switch installed and the actuators.
2012 Black 1LS M6: Cold Air Inductions Intake w/ Scoop, McNally Dual Valve Catch Can, 2.5 Inch Exhaust, Magnaflow Resonated X-Pipe, Muffler/Resonator Delete, SS Tips, 2017 ZL1 Style Rims, 255/45r20 Front, 275/40r20 Rear, SS Bumper Conversion w/ Fog Lights and LED "Knight Rider" Scanner.
tylerng1999 is offline   Reply With Quote
Old 06-10-2018, 11:45 PM   #2
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I dig it. I wish I could turn it off at idle
TSP 231/236 111 cammed 1LE
WHAMMO is offline   Reply With Quote
Old 06-11-2018, 07:05 PM   #3
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2015 Silverado CC
You can, I found a write up somewhere in here on how to do a 3 way switch (stock, always open, always closed).
760bowtie is offline   Reply With Quote
Old 06-11-2018, 07:06 PM   #4
760bowtie
760bowtie's Avatar
https://www.camaro5.com/forums/showthread.php?t=318683
Post #9. This is assuming the car came with NPP from the factory.
Old 06-15-2018, 05:50 PM   #5
SSAvery
Avery@Texas-Speed.com
Drives: 2010 2SS/RS
Any update on this? I would be interested in something like this myself. I have the NPP but running it with open valves! Sounds awesome, but I would like to be able to close the valves in the neighborhood and on the highway. I have seen a few different vacuum related ways of controlling it, but I think an electric valve would be more of my speed.
-Avery
2010 2SS/RS - Texas Speed 1 7/8 Headers + 3" Off-Road X & NPP Axle-Back. Roto-Fab. Texas Speed Stage 3.2 Cam. SLP UDP. Aikman Performance Tuned 495 RWHP / 445 RWTQ on a DynoPack.
SSAvery is offline   Reply With Quote
Old 06-15-2018, 11:09 PM   #6
tylerng1999
-Avery
Progress is slow, taking summer classes and have at job at the moment. But it'll definitely be finished in the near future!
Old 06-16-2018, 03:40 PM   #7
tylerng1999
First challenge to address is the distance to the point where the actuator attaches to the arm to move the butterfly valve is only one inch of travel while the electric actuators have 2 inch of travel. While I wanted 1 inch travel actuators in the first place, they were significantly more expensive than the 2 inch ones I picked up. To prevent the actuators from over extending they have built in limit switches as pictured so I can either figure out how to trigger the limit switches early or move the limit switches to allow the actuator only a 1 inch throw. Thoughts besides being over engineered?
Old 06-17-2018, 08:56 AM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Turing off the exhaust is able to be accomplished with a Forza threeway controller
http://forzacomponenti.com/
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr, Powermaster xs 9509 starter, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 07-24-2018, 12:30 AM   #9
tylerng1999
Slightly disappointing but im going to go back to the vacuum actuators and simply use a vacuum solenoid valve for $15 off eBay, much less of a headache with similar results.
Old 07-24-2018, 12:50 AM   #10
tylerng1999
https://www.ebay.com/itm/272931927290
Motorized ball valve that will work with the reverse polarity switch
Old 07-24-2018, 02:15 PM   #11
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
A simple 3 way switch and 3 wires works too. the very simple solution. I wired mine in after the long tube install to appease my neighbors in the AM.
2014 2SS/RS LS3/M6 - CAI, long tubes, cat delete, Jannetty Tune
pnwdan is offline   Reply With Quote
Old 07-28-2018, 02:37 PM   #12
Blown1LE
Blown1LE's Avatar
Drives: 2015 Supercharged Camaro 1LE
Whats the easiest way to be able to control it with no vacuum lines ? Previous owner put it on and there are times I wish it was closed but I dont want it closed all the time either.
Magnuson Supercharged 2015 1LE RS/SS
Blown1LE is online now   Reply With Quote
Old 07-28-2018, 03:19 PM   #13
tylerng1999
Vacuum lines is going to be the easiest I believe, there's a kit called "Mild to wild" that allows you to open and and close it on command but it's a little expensive in my opinion, my first attempt was to remove the original factory vacuum actuators and replace with with electric ones hut would require alot of fabrication. I think my new plan with the motorized ball valve is the best way to go. My car is a V6 so it has none of the NPP vaccum lines but I do have a catch can installed. So my plan is to run a reducing tee into one of the catch can lines to go through the motorized ball valve and then run one vacuum line to the rear and another tee to split to each muffler. The vacuum at idol is enough to close the valves so with the motorized ball valve and a reverse polarity switch, you can have full open or full close at any rpm.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
