11-19-2010, 10:56 PM | #1 |
Drives: 2011 Camaro 2SS RS Join Date: Jun 2010
Location of turn signal flasher?
Anyone know where the flasher units are for the 5th gen? Putting in some LED turn signals and don't want to bother with load resistors.
I looked in the fuse block under the hood and also the block on the inside of the drivers door. Perhaps I overlooked it. I found an old thread for 4th gen Camaro's, and it looks like the flasher unit is buried in wiring under the steering column. Hope that is still not the case.
1100 Order Placed at Dealership: 06.25.10
2000 Order Accepted by GM: 06.29.10 2500 Order Preferenced: 06.30.10 3400 Order Broadcast: 07.01.10 3800 Order Produced: 07.26.10 4000 Available to Ship from Osh: 07.27.10 4200 In Transit from Osh: 07.28.10 4800 Rail Ramp Unload: 08.06.10 5000 Delivered to Dealer: 08.07.10 6000 Delivered to Customer: 08.07.10 |
11-20-2010, 12:07 AM | #2 |
Drives: '10 Camaro 2SS/RS CGM LS3 A6 Join Date: May 2009
Its built into the computer programming, there is no physical flasher module like on cars of old.
You'll have to install some load resistors. But its worth it. I have LEDs all around, and I love them.
- 2010 Camaro 2SS/RS CGM LS3 A6 "Lurch" - FLYNGSS -
Some ProCharger, Alky, CompCams, Brian Tooley, Holley, Livernois, K&N, Ridetech, DSS, Kooks, JDP Motorsports, Pfadt, BMR, Prothane, Weld, M&H, Mickey Thompson, RKSport, Elite, Garys, Defenderworx, Anvil, etc. |
11-20-2010, 03:18 AM | #3 |
Drives: 2011 2SS/RS A6 Join Date: Aug 2010
The clicking sound when the turn signal is on comes from the drivers door speaker. Open the door and get the ding ding sound the turn signal click stops. I guess it can only produce one sound at a time. LED's work great with resistors added. The flasher upgrade for LED's is what I wanted to do, but not possible.
JRE custom tune, AIRAID cai, VMAX spiral ported throttle body,
BORLA shorty headers, SOLO hi flo cats & mach-xl cat back, RX catch can/breather cap, MTI plug wires SPARKS SS emblems, PUTCO mailslot led, AAC led side markers, AUTOLUMINATION drl's, f/r turn sig,dome, trunk, license led's, SOUTHERN CAR PARTS sequential turn signals, BIG WORM GRAPHICS hood spears, mail slot, gills 3M CRYSTALLINE 40% window tint HURST shifter/plate, GMPARTS quarter flares RPI flat black bezels and rjt license plate frame STREET SCENE chin splitter |
11-20-2010, 09:42 AM | #4 |
Drives: 2016 2SS, SW Join Date: Oct 2009
I've chosen to deal with the fault messages instead of installing heaters at all four corners.
11-20-2010, 10:17 AM | #5 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
LOL thats one way.
11-20-2010, 12:08 PM | #6 |
Thanks guys, explains why I couldn't find it :-)
11-20-2010, 06:29 PM | #7 |
The resistors don"t seem to get that hot compared to the heat of the OEM light bulb. Besides the bulb out message, the turn signals will flash very fast with just the LED's.
11-20-2010, 08:32 PM | #8 |
Not necessarily!
11-21-2010, 01:53 AM | #9 |
Here's a little more info about the load resistors:
http://www.camaro5.com/forums/showth...=1#post2566773
02-19-2012, 02:54 AM | #10 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
I seem to be having the problem with the bulb out as well as the fast flashing on my left side. How fo I correct this? I installed the afterburners myself and also will be installing a new pair of plasma fog lights with a dry harness.
10-07-2013, 01:07 PM | #11 |
Drives: 2014 Camaro LT RS in Red Hot Join Date: Aug 2013
Has anyone had any luck with a plug and play resistor?
I was looking at this product, which appears to be a plug and play resistor. Anyone have any luck with something like this? Seems like it would work great...
http://www.amazon.com/Amico-Warning-.../dp/B00BLZ7WLS Really want to do a Full LED Conversion but dont have the know how to wire in resistors. Also dont want to splice into a brand new cars wires. |
10-07-2013, 07:44 PM | #12 |
Drives: '16 2SS Join Date: Apr 2011
Those don't usually work for the Camaro (wrong load).
We have a plug-n-play version that does work, or, one that connects via quality t-taps. |
05-11-2021, 11:08 PM | #13 |
Spyder led tail lights
I have spider led tail lights that have been in since last July ,just recently I have a error code check turn signal bulbs but bulbs are fine ,what could after 10 months of no problem cause this to happen I unplug the battery but only for about a couple minutes should I wait longer and try again ,spyder says the resistors are build in on these
05-13-2021, 06:04 AM | #14 |
Banned
Drives: 2010 LS Join Date: Feb 2021
LEDs draw less current, the body control module thinks they're out. I live with the
warnings. I could program that on on my VE Jettas with VCDS. Too bad there isn't a tool like that so you can access the BCM and make changes. |
Thread Tools | |
Similar Threads | ||||
Turn signal noise | levi1922 | 5th Gen Camaro SS LS LT General Discussions | 5 | 03-22-2010 12:40 PM |
Got blue turn signal/ running lights :-) | 5th_GEN_SS | Cosmetics and Lighting Modification Discussions | 11 | 02-24-2010 06:46 PM |
please help with removing turn signal bulbs | 5th_GEN_SS | 5th Gen Camaro SS LS LT General Discussions | 8 | 02-23-2010 08:15 PM |
Power door Locks how to turn off | JCSSCamaro | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 6 | 02-23-2010 06:42 PM |
Colored turning signal bulbs? | 5th_GEN_SS | Cosmetics and Lighting Modification Discussions | 16 | 02-12-2010 08:24 PM |
