04-18-2020, 12:40 AM | #1 |
Drives: 2014 Chevrolet Camaro LS Join Date: Feb 2019
Water inside taillight
Hello, so today while out to shop I noticed the right side of my right taillight was out on my 2014 Camaro LS and I decided to go take a look at it. Turns out half the taillight is full of water... yes a bunch of water. I hadn’t noticed since I just drive my car to work and nothing else lately. I’m unsure on what to do right now, take it to a Chevy Dealer even if I got it used from some other dealers? Somehow drain the water out? Need completely new taillights?
04-18-2020, 02:07 AM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Best solution I’ve heard was too drill a small hole or two on the bottom of the twilights. You won’t really see the wholes
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-18-2020, 06:53 AM | #3 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Drill a very small hole in the bottom corner. There is a thread on this from a couple weeks ago. You can read more here https://www.camaro5.com/forums/showthread.php?t=572938
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
04-18-2020, 09:20 AM | #4 |
Thanks guys, I looked for a similar thread but kept getting threads about condensation. Ill do this and replace the bulb. Thanks!
04-18-2020, 10:54 AM | #5 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
I'd take the whole tailight out and find out where the water is coming in and then reseal it. It must be a fairly large hole or gap for that much water to seep in. If it's sonic welded and the plastic cracked or it can't be resealed for some reason, then I'd just look for a good new/used tailight.
Even with holes drilled into the bottom, it's probabaly not a good idea for water to be constantly entering through the tail light housing like that. |
04-18-2020, 01:03 PM | #6 |
You can drill a small hole and let it dry completely then seal it back up with some clear sealer. It will be so small you will have to look for for it to see it.
04-18-2020, 03:08 PM | #7 |
Banned
Drives: cheby Camaro Join Date: Aug 2019
I've tried to repair them in the past without any luck. Its very hard to find the breach because it can change with temperature. I even went as far as pressurizing them under water and couldn't find a thing but they still leaked water. The water vapor in the taillight ruins the reflective coating pretty quick too.
04-18-2020, 10:30 PM | #8 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
If a customer doesn’t want to replace the assembly because of cost etc....
I will smoke the assembly and then seal if possible with clear silicone |
04-19-2020, 03:33 PM | #9 |
Drives: 2011 VR SS Vert Join Date: Aug 2015
Make sure the bulb is seated correctly. I found some moisture and the bulb was not seated correctly in the tail light housing.
09-15-2020, 06:13 PM | #10 |
2014 Camaro 2SS RS 1LE
Drives: 2014 Chevrolet Camaro 2SS 1LE RS Join Date: Mar 2020
My wife just jokingly suggested putting silicon packets in there to keep it dry, which puts a pretty funny mental image in my mind of those rattling around while my cammed engine rumbles.
09-15-2020, 07:17 PM | #11 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
09-16-2020, 02:03 PM | #12 |
09-16-2020, 05:39 PM | #13 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
This is ‘blinker fluid.’ Replace when dry.
