05-07-2021, 02:34 PM | #1 |
Drives: 2015 Camaro SS Join Date: Mar 2021
Car struggling to turn over when warmed up
I have this issue with the car starting up
I can fire it up a couple times back to back but once driven and the car warms up it turns over slowly the next time I fire it up unless I give it time to cool down I initially thought it was the battery but had it tested came back good Has any had this issue before or know what it could be |
05-07-2021, 03:07 PM | #2 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
Starter being heat soaked from the exhaust possibly. Make sure there is a heat shield or some sort of heat protective something between the starter and the exhaust.
05-07-2021, 03:08 PM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I haven't experienced this on my Camaro, but with my Monte Carlo this was a common problem when the fuel pressure was low because of a bad regulator and/or an issue with the MAF sensor.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-07-2021, 04:34 PM | #4 |
Drives: 15 Camaro SS Join Date: Oct 2018
Possibly heat soaked starter, but check grounds. With a battery in the rear, these cars are known to have shitty grounds and cause starting issues
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
05-07-2021, 05:37 PM | #5 |
Thanks I look into both and see what I find
05-10-2021, 01:10 PM | #6 |
Scott S
Drives: 2011 Camaro 2SS Join Date: Sep 2018
Run a ground wire from the starter to frame...
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
