Old 01-09-2011, 05:32 PM   #1
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Whats the cold Cranking Amps on a 2010 Camaro's battery ?
Does Anyone know Whats the cold Cranking Amps happens to be on a 2010 Camaro battery ?
My battery shows to be charing from the 4 pack guages. on Mornings when its 65+ or 45+ outside when the car has Sat there all night it Cranks fine.
On mornings where its 35 or below it has a slow crank to it almost like it has a hard time cranking over however it does happen to crank over. After it does start the Guage shows its charging normally.
I removed the battery terminals off the battery and and cleaned the battery post and terminal then reassembled everything making sure there was a tight connection. I'm sure when the motor was removed during the Cam install and DOD delete everything was tightened back to where it needs to be.
I wouldnt think its the alternator because on warm mornings it cranks up meaning it is actually charging.
Could a New Car possibly have a bad battery ? could it have a bad cell where only on cold mornings it seems to not want to start normally ?
I thought about taking it up to the autostore and having them put the tester on the battery putting a load on it to see if its working. they can also test the alternator at the same time if neither one of those are the answer then its time to get with either the dealership or probably the person who worked on the cam intall and see what he thinks.
Jekyll-N-Hyde is offline   Reply With Quote
Old 01-09-2011, 06:18 PM   #2
R6P
R6P's Avatar
Drives: 2010 Camaro
The battery is rated at 720 CCA
R6P is offline   Reply With Quote
Old 01-09-2011, 07:59 PM   #3
Jekyll-N-Hyde
Thank you
GM PR: Chevrolet Attends Camaro5Fest, the largest-ever gathering of 2010 Camaros Tran 2010 Camaro5 Fest (I) 41 04-21-2010 01:50 AM
4 2010 Camaros in stock, available Frank in MD Dealer Camaros for Sale 21 11-29-2009 01:11 PM
Chance to drive 2010 Camaros...... fbodfather 5th Gen Camaro SS LS LT General Discussions 15 06-18-2009 08:13 AM
