09-16-2016, 08:42 PM | #1 |
Drives: 2013 1SS/RS CAMARO Join Date: Jul 2011
MPD1 Hood adjustment
I need some tips for my hood. Its not lined up very good on the passenger side. Its almost raised alittle. All the rubber bumpers are lowered in the front. Im not sure what to do
09-16-2016, 10:11 PM | #2 |
Drives: 2012 1SS M6 IOM Join Date: Dec 2012
Is the back where it meets the windshield, flush with the fender?
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018. |
09-16-2016, 10:30 PM | #3 |
No.. It sits below the fender alittle
09-16-2016, 10:32 PM | #4 |
Drives: 2012 2SS/RS black camaro Join Date: Jul 2011
I have the same problem with the zl1 hood I bought
09-16-2016, 10:58 PM | #5 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Based on the picture and what you've said, sounds like the hood might be slightly warped. Given that you said it's low at the rear (near the windshield) you could try putting a thin shim between the hood and the right hood hinge; just thick enough to bring the rear up flush with the fender. This should push the front down so that, with some adjustment on the front rubber spacers, it will be flush with the front part of the fender/front bumper.
09-17-2016, 11:03 AM | #6 |
Should I just use washers for shims?
09-17-2016, 11:15 AM | #7 |
I would use a shim cut to the same size as the hinge part that bolts to hood. This would ensure the hood still has good solid support from the hinge; using washers would leave gaps between the hood and the hinge which could cause problems/damage down the road
{Added} In addition to being functionally better, a shim would look better, you could paint it (the edges) to match the hinge and it would barely noticeable. Using washers would result in a noticeable gap/space between the hood & hinge.
09-17-2016, 03:50 PM | #8 |
2011 Camaro SS
1999 Camaro SS 1969 Camaro http://www.fquick.com/csmith4153 https://www.youtube.com/channel/UCKH...lQFJSUtgrNEY7w |
09-21-2016, 09:13 PM | #9 |
Drives: Cool parts for cool cars Join Date: Sep 2009
There is a bolt on the hinge with a rubber snubber over it. Take that off and adjust with a 7 mm wrench. No Shims necessary there. The front you can shim with washers to bring it up even with the hood. Call me if you need any further help
Eric@ 219-548-2673 |
