04-28-2024, 09:57 AM | #1 |
Drives: chevrolet camaro zl1 1le Join Date: Apr 2023
braking issues on 21 zle
21 zl1 1le with 6spd, 12k miles. I don't track the car but do go for spirited drives on twisty mountain roads. I bought the car last year with 3600 miles on her. The very first spirited drive i went on, after 5 minutes of aggressive braking, the brakes start to hum and the pedal gets stiff with a huge loss of braking power. When this happens, i can tone it down for 5 minutes and then the hum is gone and pedal is normal until i start using the brakes aggressively again. I did the brake booster test where i pumped the brakes with the car off and got the stiff pedal and then started the car and the pedal does go down a little so i dont think its the booster. Fluid is full also and i don't see any cracks in the vacuum line. I did replace the pads but the old ones were oem and still had plenty of pad material. In the picture, the old pads are in front of the new ones. Has anyone else experienced this issue? Thanks for any insight.
Last edited by redline_or_nothing; 05-07-2024 at 06:45 PM. Reason: added picture |
04-28-2024, 10:02 AM | #2 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Have you checked the actual pads, they might be gone.
04-28-2024, 01:08 PM | #3 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Sounds like pad fade.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
04-29-2024, 02:14 AM | #4 |
Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
I also would look if the pads are OEM ones or not. Maybe the original owner was willing to forego some braking power for less dust.
Geoff |
04-29-2024, 03:00 PM | #5 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
Lots of owners put ceramic pads like Powerstop Z26 pads for eliminating brake dust. Flip side - loss of braking power when you push it properly.
#SAVETHEMANUALS
05-07-2024, 06:47 PM | #6 |
I replaced the brake pads with new oem pads but the old ones still had plenty of material. I added a pic to the original post. I will hopefully get a chance this weekend to try out the new pads.
05-08-2024, 01:16 PM | #7 |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
Those pads look pretty good, and based on the rusty surface I'd guess they were the stock semi-metallic and not the Z26 ceramic.
I would look over the brake booster pump (behind left headlight) and associated check valves in the plumbing. Since you bought used, there is chance somebody "adjusted" things. I don't think you are overheating the brake fluid. OTOH, if you are low on booster vacuum, it should set a DTC: https://www.camaro6.com/forums/showp...5&postcount=16 |
05-08-2024, 06:17 PM | #8 | |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
