06-14-2019, 05:08 PM | #1 |
Drives: 2013 Rally Yellow 2SS/RS Vert Join Date: Nov 2013
Passenger Quarter Glass '13 2SS
Hello,
Haven't posted much as I haven't driven my car a whole lot. I bought it new May of 2013 and I have less than 20k miles. It's a great car. The only thing I've done to it is pop in a Range AFM disabler and swap out the P-Zeros for a set of Michelin AS3+ Today I got to drive it (top down of course) and when I raised the windows something was wrong. The weatherstrip (or whatever you call it) that seals between the door window and the quarter glass came off. It fell down inside the car but I was able to retrieve it easily. When I called the dealer they said that strip is "part of the glass" ie. they don't sell it. It's clearly just "glued on". New window is nearly $300 plus labor plus aftermarket tint match. Crap...but I have the piece. Any idea of some good adhesive to stick it back on there? Thanks in advance. |
06-15-2019, 01:09 PM | #2 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Show pics!
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
06-17-2019, 11:16 AM | #3 |
Drives: 2020 Camaro 2SS Convertible Join Date: Sep 2018
i would try going to a glass place them might be able to glue it back on.
06-22-2019, 08:47 AM | #4 |
Kept The Faith
Drives: 2011 Camaro SS Convertible Join Date: Jan 2007
it should be a metal frame with the rubber attched and a press fit on the glass. A good weatherstrip adhesive should work. Check why it came off in the first place - make sure it's not catching.
2011 Vert - 2SS/RS 6spd Triple Black
06-23-2019, 07:29 PM | #5 |
Mine did the exact same thing. Since there is a lot of pressure on this piece I needed something strong so I used 5 min epoxy. Keep in mind that it needs to seal with the front window so placement when glueing is important.
Black GFX / Dynatech Supermaxx LT Headers / FR Black Chrome ZL1 Replicas 275/315 / RDP Tune / CAI / VMAX TB / MBRP SS Catback / Gtechniq CSL & EXOV3 / VTC / RX Catch Can / Valentine 1 / Halo DRL / LED Fogs
