04-29-2021, 01:30 PM | #1 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
First gear lurch/lag
This has bugged me from the first time I drove my car. When I am in first going from a full stop at a low to normal speed the car hesitates and then lurches forward when the clutch is about 3/4 of the way released.
When I am at a place where I can go faster I give it more gas and all is well. But when I am behind someone at a stop sign or stop light it always heaves forward. My kid makes a comment everytime! If this is just part of the deal then I can live with it, but if there is something I can do I will do it tonight!
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
04-29-2021, 01:36 PM | #2 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
If this is the same program that the automatic uses, your car (computer) attempts to match the engine speed with the vehicle speed. It almost never matches up quite right, it just lurches forward like you say. You are expecting the classic downshift resistance of deceleration but what you get is the opposite. It’s in the programming. Crazy, I know. Why, I’m not sure.
I think they ‘attempted’ to avoid the decel lurch where you go forward. But what they created was you going backwards!
04-29-2021, 01:40 PM | #3 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I have it too. Two things that helped are lower gear ratio and aluminum driveshaft. What makes it more annoying is when the Prius in front of you wants to drive like it's trying to hit 70mpg.
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-29-2021, 01:46 PM | #4 |
It has a name and has been discussed here before. Seems odd that it can’t - or doesn’t, get tuned out with a tune mod. I’m tuned but it’s still there.
Update: apparently it’s called, “rev hang” or rev matching And can be Googled, etc...
04-29-2021, 03:29 PM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Mine does it...mostly when cold. The other half of the time it's the 2 piece drive shaft and drivetrain slack. Also, it something you had to work around when cammed.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-29-2021, 07:03 PM | #6 |
Valkyrie14
Rev-Hang...awesome. Well I can add gears and driveshaft to the wishlist.
04-30-2021, 07:23 AM | #7 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I am not sure what you are talking about. When my car had the stock cam I had no issue at slow speeds. With the rough idle cam I get lurching at very low rpm but that is the nature of having a cammed car. You can raise the rpm higher and slip the clutch a little more if needed. Not sure if your car is cammed or not. If it's not you may need a better tune. If it's cammed you are feeling the lurch of the rough idle
04-30-2021, 09:06 AM | #8 | |
Valkyrie14
It is just a thing, I think I am at the end of what my current tuner will do for what I paid. Waiting for another mod to find another tuner. Going to back to my original tuner and get a street tune. Probably after my cam. He also has a dyno and I might throw down the cash to get a real rwhp number verified.
04-30-2021, 09:19 AM | #9 | |
04-30-2021, 09:21 AM | #10 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
05-02-2021, 05:14 AM | #11 |
Drives: 2014 camaro SS Join Date: Jan 2019
sounds to me that you are not pushing in the clutch soon enough when you come to a stop. rev hang and rev match are 2 different things. the only common denominator is "rev"
05-03-2021, 02:53 PM | #12 | |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
05-18-2024, 08:09 PM | #13 | |
Drives: Firebird 95, Equinox 05, Camaro 2SS Join Date: Aug 2009
Mine developed the same issue... just two/three weeks ago
It just started about two or three weeks ago This past Tuesday I just took the car to an scheduled full fluids maintenance:
It was due by age and by milage: my CAMARO 2SS just reached 25,000 miles. When I picked up from the service shop it was silk smooth, just like when I purchased it 14 1/2 years ago! Since then, the issue has come back, yet intermittently. I wasn't like that for the previous 14 years: from day one, as long as I modulated the clutch release properly and precisely (in measured increments around its pick up point) there were no lurches, no unintended surging forward. Next week I'm getting a local top Pro-shop which specializes in Pony Cars and CORVETTES to do a diagnostic on the issue. I'm pretty sure its a warped or scoured pressure plate (a few times I've been getting "pulsating" jolts during medium-hard to high hard acceleration, though not always) but I want the Pro's to give me a proper assessment. As soon as I get the diagnostic (and hopefully some pics) I will post it here so you can use it as reference to work out your problem.
05-20-2024, 11:45 AM | #14 |
Drives: 2012 Camaro 2SS Join Date: Jun 2023
Are you lugging it below idle speed? In traffic, I've noticed mine will try to maintain idle speed even when crawling along in 1st riding the brakes if I lug it down below 500rpm.
