Old 10-15-2018, 08:16 AM   #1
Matty Ice
Matty Ice's Avatar
Drives: 2015 SS/RS 1LE
Diff Bushing Replacement
I need to replace my differential bushings and need some help deciding which ones to go with. For those of you that have done this, any feedback/recommendations would be great. I want to go with the Derlin type but I'm leery based on some of the complaints of the NVH. I am also looking at the off set bushings as I am lowered on -1.25 BMR springs. Any advice/suggestions would be helpful. THANKS!
FYI- I have done a search and looking for more recent and detailed info.
Matty Ice is offline   Reply With Quote
Old 10-15-2018, 03:10 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Why do you think you need new Diff Bushings?
anything harder than OEM will provide NVH a path to travel through.
Old 10-15-2018, 03:41 PM   #3
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2007 Silverado LTZ
I have the BMR Delrin bushings on mine you are going to get move NVH to me it was acceptable, my car is not a daily driver it may see 600 to 1000 miles a year so if you drive it every day it may be more noise than you want. I was looking to stiffen up the rear suspension as much as possible for drag racing.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 10-15-2018, 03:57 PM   #4
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
I have BMR’s bushings. My car is a daily and it is definitely more jolting on bumps than stock and you do get more NVH all around but to me it’s really not much of an inconvenience, and I don’t think it would really bother most people all that much
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 10-15-2018, 04:52 PM   #5
AG1LE
AG1LE's Avatar
Drives: '14 1LE
I have the delrin offset bushings in a Z/28 differential, and get a lot of noise; however, I also have a lot of other suspension-stiffening upgrades (some of which I installed at the same time as the delrin diff bushings) that increase NVH, so it would be difficult to compare. I also have LT headers with no cats and often leave the NPP "open" - this probably also contributes to how much NVH is noticeable in the cabin.
I've mostly gotten used to it, and now just chalk it up to "race car noises".
You may want to list your other suspension-stiffening upgrades and see if anyone with a similar setup could provide feedback relevant to your setup.
AG1LE is offline   Reply With Quote
Old 10-15-2018, 05:26 PM   #6
brick59
Sucker Punch
brick59's Avatar
I agree with AG1LE I have BMR everything under my car and it was done all at the same time so the noise adds up.
Old 10-15-2018, 11:32 PM   #7
Matty Ice
Matty Ice's Avatar
Thanks everyone for the replies, much appreciated. I put on about 3k miles a year. My current mods are: Z28 CAI, LT's, hi-flo cats with the NPP fuse pulled, -1.25 BMR's, B6's, JPSS rear sway, Z28 RUCA bushings, JPSS castor locks. So this thing is pretty noisy now.
I have a Z28 diff that going in asap, with solid rear cradle bushings next.
AG1LE- Do you feel the offset bushings worked/helped as advertised??? I figure if I am going with the derlin might as well go with those.
Old 10-16-2018, 04:22 AM   #8
AG1LE
AG1LE's Avatar
Drives: '14 1LE
I haven't really put them to the test. The diff bushings were something I did because I already had the diff out while doing a series of upgrades.
Old 10-16-2018, 09:41 AM   #9
Matty Ice
Matty Ice's Avatar
How do you like the Z28 diff compared to the stock one? As far as traction, did you notice a difference?
Old 10-16-2018, 04:03 PM   #10
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Subframe bushings
I just did my cradle bushings and went with solids, they are excellent.
See my post on the install, I provide a detailed instruction with tools required, sizes which will save you multiple trips back to the hardware store, a video of me removing a bushing, AND a torque spec table.
www.camaro5.com/forums/showthread.php?t=540578
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 10-17-2018, 04:20 PM   #11
Matty Ice
Matty Ice's Avatar
Yep! I already have that printed out, saw it when you posted. Thanks for putting that info out there.
Old 10-17-2018, 04:30 PM   #12
Chris49066SS
Drives: 2010 SS L99
No problem, glad to help
