Old 12-15-2013, 09:09 PM   #1
LS3 Handler
I love the LS3
LS3 Handler's Avatar
Drives: 2010 IOM 2SS Manual
Dear GM: Why the AY6?
I have done everything I have heard of to get the issues from shifting from 1-2 at WOT throttle done away with. Ive got Amsoil Manual Tranny fluid in it, MGW shifter, IDEALG Modified master cylinder, remote reservoir with Amsoil DOT4 high temp fluid. When I first installed the new master cylinder everything seemed ok I could even powershift it with no problems. Well that was a few months ago. On the way home I stopped on a closed street for a little fun. No matter if I left the line easy or hard I could not get it to shift from 1-2 at WOT the tranny would block the gear out. I even tried shifting early at 6k and I was still blocked. I just don't know what else to do. Damn chevy for getting every about the car right except for when I want to drive my sports car like a sports car. Does any one else have any suggestions.
LS3 Handler is offline   Reply With Quote
Old 12-16-2013, 02:51 PM   #2
LS3 Handler
I love the LS3
Well today I discovered that after I make a turn and am on a roll I can stomp on it and take it to redline and make a good 1-2 shift. BUT every time I go WOT in a straight line no matter if I spin or not the tranny will still block me out of second. I taking it to the dealer on Friday to see what they say but who knows this is getting old.
Old 12-17-2013, 12:44 PM   #3
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Had mine at the dealer for a week in November - demonstrated the grind to a tech, sr tech, shop foreman and a tranny specialist. Gave them the part numbers for the new carbon blockers and they they still couldn't figure it out. Guess I will wait till 2nd falls out of the tranny and have it towed in - maybe if it's actually broken they can get an idea of what the issue is.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 12-17-2013, 06:28 PM   #4
12WhiteLS
12WhiteLS's Avatar
Drives: 2012 Camaro 1LS M6
This has to be my biggest complaint as well. I've had issues with mine from the beginning with the dealership shrugging it off as normal or as driving technique. I was hoping that all of the mods you have done would help.
12WhiteLS is offline   Reply With Quote
Old 12-17-2013, 08:16 PM   #5
LS3 Handler
I love the LS3
Its helped with some peoples but not mine. Ive the grinding issues sence ive had it and all those upgrades has kept from grinding so i dont have any grinding at all but it dosent help when the tranny stops me from going into 2nd.
Old 12-17-2013, 08:21 PM   #6
Steve@SNL/Monster Clutch
Drives: 2014 SS
I'm leaning towards the clutch... these things are anemic to say the least and they're not going to take abuse well.
That said, the internals are weak, plain and simple.
And for the techs to outright ignore it on Yellow_Glide's visit is just plain insane. Not surprising... just insane.
Gotta love GM/stealerships.
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 12-17-2013, 08:55 PM   #7
LS3 Handler
I love the LS3
Yea, well im hopeing i can talk my way into them doing something, i dont want my car i be in the shop but somthings gotta give i cant keep driving and paying for a sports car that i cant have fun with, thats why i bought it.
Old 12-17-2013, 09:56 PM   #8
Drives: 2014 SS
I hear you man.
Keep us posted on what they do.
Old 12-18-2013, 03:56 PM   #9
Yellow_Glide
I would be willing to do a complete swap if all the peices were available.
Old 12-18-2013, 08:23 PM   #10
12WhiteLS
12WhiteLS's Avatar
Just theoretically, if a bell housing adapter was made, how hard would it to swap a Tremec in there?
Old 12-18-2013, 10:59 PM   #11
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
There would probably be some wiring harness issues and programming needed for the speedometer. The Tremec TR-3160 is used in the new Cadillac ATS and looks very similar to the AY6. I wonder if that is another possibility.
Mark114 is online now   Reply With Quote
Old 12-19-2013, 12:27 PM   #12
Yellow_Glide
Looks like the tr3160 is rated for 310 ft lbs tq - and with hollow shafts and web gears - def not for high hp or boosted.
Old 12-19-2013, 10:51 PM   #13
Mark114
Mark114's Avatar
The Aisin AY6 is rated for 345 ft·lbf (468 N·m). Unless I'm reading this wrong Tremec's web site shows several variants of the 3160 with input specs as high as 425 ft·lbf (576 N·m).
http://www.tremec.com/anexos/File/TR...ansmission.pdf
Old 12-20-2013, 02:48 AM   #14
RenegadeSS
RenegadeSS's Avatar
Drives: Camaro LLT
Isn't this the trans that is on the 2.0 ecotec?
RenegadeSS is offline   Reply With Quote
