11-30-2018, 08:05 AM | #1 |
Drives: Anything I want Join Date: Oct 2008
ADM 442 CID LS7- High compression
I have an engine we recently swapped from my trailblazer Ss
Back to stock . It was built by LME back in 2008. We just freshened it up and updated it to 58x reluctor As well as new pistons rings and bearings It is a ready to go short block. Price reduced to $5000 firm -12-23-18 We can also fully dress it out for someone wanting It complete. Last edited by ADM PERFORMANCE; 12-23-2018 at 08:14 AM. |
12-23-2018, 08:09 AM | #2 |
LME 445 CID Race Motor
We also have this engine available from this car that we recently demoded and sold-
https://www.corvette-mag.com/issues/...l#.XB-WdWeWzwo LME 445 CID Solid Roller Motor - 800+HP N/A 1- 2012 RHS Standard 9.240 Deck Block,Billet Main Caps,Priority Main Oiling 6 bolt per cylinder.750 deck thickness with raised Cam for long stroke 4.165 " bore capable. 1- Callies Dragon Slayer 4340 4.100 stroke crankshaft w/LS7 Long 1- Callies Ultra Billet 6.125" H beam rods W/ ARP 2000 7/16 Bolts 1- Wiseco 4.155 Custom Pistons W/ Lateral Gas Ports and Anti friction coating 1- Total Seal Stainless chrome top ring,Napier 2nd and 3mm ht oil 1- Clevite MS2199 H Mains,Clevite CB663 Rod,Durabond CH-23 Cam Bearings 1- GM DR CNC Ported and Assembled Cylinder heads with Ferrera 2.25" Titanium Intake Valve and Ferrare1.625 Exh Valve 1-Pac Dual Solid roller springs(Good to .900 lift) 1-Ferrera Titanium Retainers 1-Machined locators and viton seals 1-Heads flow 435cfm@.800 lift 1-cam motion lsx solid roller cam 1-Cloyes Hexadj for raised cam block with torrington bearing and nitride gears 1-ISKY LSX Tie bar solid roller .842" Lifters with EZXRollerBushing 1-Smith Brothers Three Piece 7/16 x .165" wall taper pushrods 1-T/D Shaft Mounted Rockers for GM DR Heads 1-Cometic MLS Gaskets 1-ARP PRO 2000 12 pt head studs for 6 bolt heads made of 8740 chromoly 1-GM Ls7 Oil pump - Ported with thicker scavange G rotor for 30% increase scavange as well as billet front cover to accept thicker gear 1-A R E Dry sump pan with scavange line machined for -10 or -12 tank in/out fittings included 1-Ls2 front cover 1- Custom twin trottlebody intake for twin 102mm throttlebodys 1-ATI 10% Underdrive 1-Valvecovers for DR Heads 1-Billet Coil relocation brackets 1-Pro Efi engine managment system for corvette 1- American Racing Custom Headers for Corvette and DR Heads with Xpipe Original Cost was over $40,000 for all the above Asking $14995 |
12-28-2018, 08:43 PM | #3 | |
Drives: ZL1 Join Date: Mar 2018
12-29-2018, 09:56 AM | #4 |
Drives: 2010 Camaro SS Join Date: Jan 2017
Interested, would like info on the build.
01-01-2019, 10:38 PM | #5 |
Drives: 2010 Camaro Join Date: Nov 2018
01-05-2019, 10:49 AM | #6 |
The article answers these wuestions
If you want to call and discuss more than what has already
Been stated I will gladly give you what I know. |
01-06-2019, 04:41 PM | #7 |
So it’s a dry sump. How did you run that in the TBSS? Will call you during the week.
08-17-2019, 04:51 AM | #8 |
No it was a wetsump
