Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 02-24-2017, 11:38 AM   #1
Bradley
Gray Eagle
Bradley's Avatar
Drives: 2010 Camaro 2SS/RS IBM, 1994 Camaro
Key lock cylinder replacement
I'm looking for a DIY on how to replace the lock cylinder on a 1990 Camaro. Does anyone have a guide of know where to find a guide?
Thanks in advance.
Ordered - 14 Aug 2009 Born - 4 Nov 2009 Delivered - 17 Dec 2009
Bradley is offline   Reply With Quote
Old 02-25-2017, 01:44 PM   #2
scott's45
Scott's45
Drives: 2012 2SS 45th Anniversary
I went into youtube and typed "cylinder lock replacement camaro" in the search box. a few videos popped up. see if one of them helps.
scott's45 is offline   Reply With Quote
Old 03-08-2018, 12:50 PM   #3
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
When you say lock cylinder do you mean the ignition switch? If so, you will have to have your original key measured for resistance at the dealership which is 1 thru 15 so the right blank can be use to cut the new key. Then you will have to train the new key once the cylinder is replaced. It's not that hard. I did it on a 2003 Buick Regal.
ZEN357 is offline   Reply With Quote
Old 04-10-2018, 09:13 AM   #4
ZEN357
ZEN357's Avatar
You'll need to train the key otherwise it will think you are stealing it
Old 12-07-2018, 05:55 PM   #5
atikovi
Drives: 1994 Camaro Z28
Ignition, doors, hatch, storage bin? Need more details.
atikovi is offline   Reply With Quote
