Old 11-21-2024, 02:29 PM   #1
gmcrash
Drives: 2012 Synergy Camaro SS, 2014 2SS/RS
Hood release cable broke how can i get hood open
My hood release cable broke on 2012 2SS how can i get open
gmcrash is offline   Reply With Quote
Old 11-21-2024, 11:58 PM   #2
King Nothing
Turning wrenches
King Nothing's Avatar
Drives: 2011 Camaro SS By Berger 11BC21
Normally I can think of something, in this situation I can’t think of anything. Call your local dealership and ask them if it’s something they have seen.
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
Sold-2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
1 of 25 and only SIM Camaro By Berger in 2011 year, 2011 Camaro 2SS/RS M6 By Berger #11BC21
King Nothing is offline   Reply With Quote
Old 11-22-2024, 03:44 PM   #3
gmcrash
Dealership told me to go check with a local body shop and they said they had no idea what to do
Old 11-22-2024, 08:07 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Maybe it might be possible to get to the latch from the front of the car through the grille? I know you can adjust the height of the latch up and down from that way, that's how we did mine when installing the custom hood, maybe a long big screwdriver or pry bar could unlatch it. Worth a try since there will be no tension on the cable. Good luck..
Old 11-22-2024, 08:59 PM   #5
Bee
Bee's Avatar
Drives: SS/RS - Rally Yellow
I would maybe start on the interior at the hood release...you may luck out and find that the cable broke at the handle. If not, I would go with 1JEWLD's suggestion and try to come in through the grill.
The area in front of the radiator is hard to get to because of the way the front bumper mounts and there's a shroud under the radiator. However, you may be able to get in better if you remove the two bolts on the bottom of the front bumper.
As a last resort, you could even try getting in through the driver's side wheel well.
Check out my build here.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 06-05-2025, 04:59 AM   #6
J35Y2
Drives: 2010 Chevy Camaro 2SS manual coupe
Any update? Or has anyone tried to get in, without being able to just pull on the broken hood latch cable, from inside of the vehicle?
J35Y2 is offline   Reply With Quote
