Old 05-09-2025, 08:02 PM   #1
Barnald
Drives: 2010 Chev camaro
Has anyone “solved” this harness bar problem…
…if it is indeed a problem.
Specifically the bar has an inch or so play in it back and forth. I’ve tried everything and searched on here extensively. I’ve come up with squat.
Thanks for reading.
https://www.camaro5.com/forums/showthread.php?t=336257
Barnald is offline   Reply With Quote
Old 05-13-2025, 06:48 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I have a Braum harness bar which looks identical, and I don't have an inch of play. If there is too much play, I would guess the heim joints are not tightened properly.
Old 05-14-2025, 07:16 PM   #3
Barnald
Thanks. I’m gonna fabricate some bars that go from the cross bar to the bolts that hold the rear seat hinge bar….can never be to careful.
