Old 06-03-2025, 10:00 PM   #1
slonison
Drives: Summit White 2012
How-to: 2012 Camaro V6 LS2 - Installing SS Center Console Auxiliary 4-Gauge Pack
In this video, I install the Camaro SS Gauge Cluster in my wife's 2012 V6 Camaro LS2.
yes this is the LS2 and this was done on an automatic
you will need to source the cluster and bezel from eBay.
part numbers
92247189 - Automatic V6 or V8
92247187 - Manual V6
92247188 - Manual V8
The reason for this is that the bezel around the cluster pack has the gear locations embossed in the trim. The gear locations in the V6 and V8 manuals are different. and the opening is different for the Automatics from the manual. so select the one you need.
you will also need a cheap aftermarket harness to tap into the data lines for the car.
link below
https://a.co/d/enmDGRD
slonison is offline   Reply With Quote
Old 06-12-2025, 10:10 PM   #2
scott71law
scott71law's Avatar
Drives: 2011 LS auto
Where do you get the cluster and bezel? When I put that part number (for a V6 auto) in it shows the harness only…
scott71law is offline   Reply With Quote
Old 06-14-2025, 09:25 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
https://www.phastekperformance.com/A...gauges-4pk.htm
Old 06-14-2025, 03:09 PM   #4
slonison
I didn't realize I don't have notifications set up on here.
I got my cluster and bezel from eBay used.
Be advised, you CANNOT use the fascia with the loose change space on it for this. The part is molded specifically to accept the gauges.
If you go ebay and put "camaro auxiliary gauges" you will get results for the harnesses and, if people are selling, the actual cluster/fascia.
https://www.ebay.com/sch/i.html?_nkw...023.m570.l1313
Old 06-19-2025, 11:39 PM   #5
J35Y2
Drives: 2010 Chevy Camaro 2SS manual coupe
Whoa... LS2 swap on an RS model... Show us what's done!!
J35Y2 is offline   Reply With Quote
Old 06-20-2025, 11:19 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I think he is confused as to what model his Camaro is! If it is a V6..
Old 06-23-2025, 06:41 PM   #7
scott71law
scott71law's Avatar
This is very helpful, thanks for posting. I’m new to the Camaro but that oil pressure does seem off- did you ever check into that? I wonder if that particular gauge is bad…
Old 08-14-2025, 01:38 AM   #8
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Lol Late reply, but he ended up saying his car trim was a 2LS trim level RS V6 model. Haha I knew there was something weird if SOMEONE even bothered trying to swap in an LS2 6.0L V8, mind you, into a 5th gen RS Camaro of all things.
TheBrightSide is offline   Reply With Quote
Old 01-06-2026, 06:48 PM   #9
slonison
Indeed. My wife has the (rare? More like rarely understood). 2LS model.
Has been quite the trip when finding parts and they always ask SS or LS. Even more confusing when I accidentally say LS2.
However, I don't believe it is an RS. Over time, I separately added the OEM heated seats, the fog lights, and the aux gauges
Old 01-07-2026, 10:22 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
If the roof ditch molding is black, and not painted the car color, then it is NOT an RS optioned car, and it would have the HID headlights with halo's if it was an RS model..
