Old 09-27-2025, 04:28 PM   #1
slipknotdude
Drives: 2013 Camaro LS
2013 Camaro Blower Motor Removal
Hey, I understand you're supposed to cut out the blower motor however I'm not exactly sure what I should be using, especially with it being such a tight space. Tried using a box cutter but that didnt do much
slipknotdude is offline   Reply With Quote
Old 09-28-2025, 02:04 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Cut out the blower motor?? For what? If you are referring to the blend door problem, some guys used a "hot knife" to cut the opening to access it...
Old 09-30-2025, 11:21 AM   #3
slipknotdude
It's a problem with the blower motor as well as the blend door. Blower motor straight up stopped working about a month or 2 ago and I've just barely gotten a replacement for it, thought it might just be the little resistor or whatever under the dash but it was definitely switching on when I'd mess with the fan settings on the climate control on the dash, the fan just wouldn't budge unless I wacked the blower. And even then it only moved a little with a quick wack. Already got it figured out on that front however, still need to replace the blend door stuff.
