12-07-2014, 02:37 AM | #1 |
Night Fury
Ethanol free gas?
I know all about 93 or 91 Octane and e85, but what is 87 Ethanol free gas for?
I know it is just gas, and doesn't have ethanol. What are the pros and cons running it?
2014 2LT RS A6
Mods: K&N Intake, Magnaflow Axleback, BMR Strut Tower Brace, VTC Throttle Controller, Tune. |
12-07-2014, 02:57 AM | #2 |
Drives: 2012 CAMARO 2SS 45TH,L99 Join Date: Oct 2014
Same benefits as any ethanol free fuel regardless of octane. For example; better and complete burning,less corrosion easier on rubber and plastic parts and better milage. Unfortunately since the demand for it is so low and the refining process is more costly it is almost impossible to find and prohibitely expensive.
Where I live here I know of only one station that has 93 octane with no ethanol. Right now regular fuel is going for$2.65 but ethanol free 93 octane is $3.60 a gallon. I drive my car very little so I usually use it unless I am on the road. In the past 10 weeks for example I have filled up only 3 times and the 3rd tank is still more than three quarters full. So since I use the car so little the price doesnt bother me and I can tell the difference.The car gets better milage and runs more smoothly without hesitation.That crap is the worse thing you can do to a car. I usually carry some anti ethanol with me as an additive when I travel on the motorcycle.I dont want that junk in my Harley. |
12-07-2014, 06:31 AM | #3 |
Drives: Dusk SE Join Date: Jun 2014
Only seen 87 octane here in FL. at WAWA did not want to run it since I usually run 93 octane and have done the fuse pull. Didn`t know if it would help or hender. If I could find 93 ethnol free I would run it every 3rd or 4th tank to keep things cleaned out.
12-07-2014, 07:45 AM | #4 |
Drives: 2016 GT vert. Join Date: Jul 2013
I personally haven't seen any benefit in paying extra for it on newer cars. I drive four vehicles, 98 Silverado, 12 Tahoe, 11 Camaro V6, 08 HD Roadking. The only one the ethanol has an affect on is the 98 Silv. I lose about 2 mpg. The others I haven't seen enough difference in mileage or performance to notice a difference. The ethanol isn't good on older cars, lawn mowers, weedeaters etc that weren't designed for it. Like others will say the ethanol will have negative effects on the seals in carbs, etc and in fuel consumption.
Something else to think about is some places that sell non-ethanol gas don't put any additives in their fuel like Techron so while you get true gas it may not have the additives to keep the valves clean etc, basically low quality expensive gas. I still buy it as much as I can for my '98, HD, and gas cans, but try to do a seafoam/techron treatment as I think about it. |
12-07-2014, 08:09 AM | #5 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
As said, newer cars are designed to run on it, but small engines and older cars can have problems. I use fuel stabilizer on my generator, chainsaw, etc. Mower is not as big a deal because it gets used a lot.
What I have had happen is oxidation in the float bowl because alcohol is hydrophilic. The oxidation (most of time rust) clogs the jets to where the engine can't get enough fuel to run. When it happens, I take the carb off, blow out the jets, clean the bowl, put it back together.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
12-07-2014, 08:48 AM | #6 |
Drives: 2010 rs 2lt Join Date: Aug 2012
Pros are it s good for cars you want to just go to point A to point B
Cons are less power for your car , Higher food prices , feeding a bad plan by big brother and business , |
12-07-2014, 08:53 AM | #7 | |
.....when the house voted to end the ethanol support the bill had an eleven page "fact sheet" footnoted . That fact sheet is the .pdf attachement...so read and decide for yourself....
"Never argue with a fool, onlookers may not be able to tell the difference." - Mark Twain "Never argue with an idiot, they drag you down to their level and beat you with experience" - Unknown |
12-07-2014, 08:57 AM | #8 |
Drives: ELLE-1 Join Date: Jul 2011
2.99 for me ethanol free 91 octane..
12-07-2014, 09:04 AM | #9 |
we don't need ethanol !!!!!
12-07-2014, 09:15 AM | #10 |
We don't need MOST things the government crams down our throats.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
12-07-2014, 09:21 AM | #11 |
Main thing is that you use Top Tier gasoline, 91 will do but 93 will give optimum performance, Top Tier has the detergents recommended by GM to keep your engine running at it's best. It cost's a little more, but I get better gas mileage on it, while keeping the fuel system clean.
12-07-2014, 09:23 AM | #12 | |
They gave a big political contribution to the Midwest freeloaders , and we were sent the bill |
12-08-2014, 10:56 AM | #13 |
Some are pulling big power numbers using E85, which is a lot cheaper than race gas. From what I read on here, some places can get E30 too. Alcohol is not all bad. The government might as well subsidize something I can use for a change cuz solar panels sure aren't doing anything for me.
12-08-2014, 12:24 PM | #14 |
Drives: 12 Boss 302 Join Date: Sep 2009
Ethanol free is preferred by boat owners and lawncare services. The ethanol absorbs water and causes issues with boats and small engines.
The biggest mistakes in life come when you know exactly what you are doing.
