04-18-2019, 10:12 PM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
key getting stuck in ignition
Thinking it may be a harness issue or shifter issue. If I smack the shifter forward a bit the key will release, but sometimes it takes quite a bit of time. This is in a L99 auto 15 SS Camaro. Any ideas? Thanks
04-18-2019, 10:22 PM | #2 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
Lots of info here... https://www.camaro5.com/forums/showthread.php?t=401624 Likely an issue with the shifter.
04-18-2019, 10:39 PM | #3 |
Ponies are for girls
put the key forward again, shift out of park then back into park. Remove key.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
04-19-2019, 05:55 AM | #4 |
Drives: 2011 RS Join Date: Jun 2018
Maybe squirtin' some powdered graphite in the key slot would help.....
Proud Owner Of '11 Camaro
04-19-2019, 07:27 AM | #5 |
This
Life is short, drive it like you stole it! |
04-19-2019, 07:56 AM | #6 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
In my case, the shifter had to be replaced. There is a solenoid that holds the ignition key in place; the shifter sends a signal to the solenoid to release the key. I was able to get around this for awhile by rowing the shifter through the gears until the key released but that eventually stopped working. Graphite would not solve the issue if this is the cause. Some people have just disconnected the solenoid instead. Most of the details around options are in the thread linked above.
04-19-2019, 10:13 AM | #7 | |
04-19-2019, 10:14 AM | #8 |
Thanks guys for the help. I'll report back here when I get into this
04-19-2019, 12:19 PM | #9 |
Drives: 15 2lt RS Top Gun Camaro Join Date: Mar 2019
Either replace the shifter assembly or remove the electrical plug from the interlock solenoid at key cylinder. The shifter assembly wears and no longer contacts the switch for the key interlock in park.
04-19-2019, 12:40 PM | #10 |
Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
Had same problem. It’s the shifter solenoid. Had to start the car again and shift out and back into park. Should be a TSB but not sure.
04-19-2019, 06:57 PM | #11 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
Mine did that. They replaced the lockout module ? On the shifter.
04-20-2019, 04:32 AM | #12 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
yep.that fixed mine too.
04-20-2019, 04:43 AM | #13 |
Drives: 2015 Topless Btch RS Join Date: Mar 2016
Had shifter replaced too
04-20-2019, 06:45 AM | #14 |
Ive read about just unplugging the solenoid. Was curious if something like this could potentially allow the key to be removed while in drive? If so this could cause an extremely unsafe situation. Any of you that have done this, maybe try and see if the key pulls out while the engine is running and the vehicle is in drive. Thanks
