Old 04-24-2020, 05:41 PM   #1
TheInfamouSS
@LS.ACE
TheInfamouSS's Avatar
Drives: 2014 Chevy Camaro 2SS/1LE
Question about Strange s5090 rear double adjustables
Does anyone else on here other than me have the Strange s5090 rear double adjustable (or single adjustable) coilovers that accept the factory springs? If so I just have a couple questions about height adjustment. The place I took it to definitely has it all jacked up.
Thanks in advance. Hope there is someone out there
Some weird snail with a belt on it | Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials |
TheInfamouSS is offline   Reply With Quote
Old 09-07-2020, 03:09 PM   #2
johnnyb305mia
Drives: 2015 Camaro SS 1LE
I'm looking at this I see no answers anybody have any input
johnnyb305mia is offline   Reply With Quote
Old 09-29-2020, 08:43 AM   #3
Morgan.13
Drives: 2011 camaro 1ss
Just picked some up too, not a lot of info out there on these. I’m going to try and make mine work with lowering springs as I don’t have the factory springs anymore.
Morgan.13 is offline   Reply With Quote
Old 01-01-2022, 05:21 AM   #4
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
I hate digging up old threads.. but not much info out there on these. Any updates on using these?
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
