Old 08-05-2020, 09:33 PM   #1
Razorbak
Drives: 2013 ZL1
Will a handheld tuner fix exhaust backfire?
Recently picked up my 2013, it has a fairly loud backfire sometimes during shifting from 1-2 and 2-3. I like the decel popping, but would like to not have the loud backfires when shifting if they can be tuned out...I’m thinking it’s because of the CAI based on searching the topic,.will one of the handheld tuners like a SCT x4 fix this? Thanks, I couldn’t find this specific question when searching, if it’s already addressed I apologize!
Oh also it may have had cutouts installed at one point that were removed, I have switches for it but definitely no cutouts present now.
Razorbak is offline   Reply With Quote
Old 08-05-2020, 10:07 PM   #2
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
You will need to disable or re-calibrate CFCO (Clutch Fuel Cut Off). Disabling will eliminate the pops while shifting, but you can also soften them by raising the timing advance when CFCO is active. You can also eliminate or soften the deceleration DFCO popping in a similar manner if so desired.
I don't know if SCT or one of the other handhelds allow you to do this, but in my limited experience, they don't.
HPTuners MPVI2 will fix you up, and give you much better logging capabilities, even if that's all you ever use it for, for the same price as the SCT x4 (once you factor in the 2 credits needed to license your ECM with HPT).
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 08-06-2020, 09:58 AM   #3
cray z1
Drives: 2014 Camaro ZL1 Red Hot Red
I have that same problem, thanks for the info, been bothering me for awhile now. Good thing I have HP Tuners
cray z1 is offline   Reply With Quote
Old 08-06-2020, 04:58 PM   #4
Razorbak
Drives: 2013 ZL1
Thanks, much appreciated!
Old 08-07-2020, 06:55 AM   #5
cray z1
Will turning off the CFCO also disable the No Lift Shift?
Old 08-07-2020, 08:55 AM   #6
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I'm not sure. I doubt it, though.
Past Rides-
