Old 01-27-2020, 04:07 PM   #1
'10CamaroDude
Drives: 2010 Camaro LS
$800 Chasing Down a P0420
First, it was both sides. Down-pipes were replaced, new cats on those, and
now it's been Bank 1. I am willing to bet they're not OEM down-pipes though.
Both sensors were replaced. The place was not clear on which ones they replaced.
I would think the downstream ones are the critical ones for determining the inefficiency.
I may have to use an O2 spacer on Bank 1, they go on the downstream sensor?
'10CamaroDude is offline   Reply With Quote
Old 01-27-2020, 04:27 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Yes to downstream. Visual is easy. If you have 4 cats they're OEM.
Downstream sensors are emissions, upstream are air fuel. Could definitely ask which set was done.
DSX_Camaro is offline   Reply With Quote
Old 01-27-2020, 04:51 PM   #3
'10CamaroDude
You can buy aftermarket down-pipes with Cats, they're all over eBay. They're $115 a
side on eBay, from Canada, and other places. He should have gotten CARB approved
CATs, even if they were aftermarket, to be safe. I won't know till I get all the paperwork.
MagnaFlow also has a set, but are more than triple the cost per side.
Canada:
https://www.ebay.com/itm/Chevy-CAMAR...0/233354171000
Magnaflow:
https://www.ebay.com/itm/Magnaflow-5...L/143360945327
This just says AP FEDERAL:
https://www.ebay.com/itm/Catalytic-C...E/392556104170
Costs the same as the Magnaflow.
Then there are the Walker brand, for the high $300s.
So, they're gonna try a spacer on Bank1.
Old 02-01-2020, 11:39 PM   #4
'10CamaroDude
Okay, so here is an update.
The code is P0430, Bank 2, which is the passenger side. Apparently this person
can't remember 20 from 30, or it switched sides with the spacers... If it WAS
20, and now 30, then all I should have to do is remove the spacer on Bank 2,
and all is fine.
Well, three sensors are Bosch, one is AC Delco. I am hoping the AC Delco is on
the driver side. I do not know which one is the AC Delco, but the failure as the
same with all four being Bosch. It has been reduced from both banks, to one.
Also, both downstream sensors have the anti-foulers on them. I doubt the
ends were drilled to 1/2 inch like most videos say. For Euro cars, they can
go in as is, but other cars, they say to drill out the hole to 1/2". Some
are putting steel wool in the spacer when put in out of the package.
The voltages match on both sensors match a lot more on Bank 2.
Fuel trim at idle is negative more on Bank 2. Diagnostic information says
when both sensors read the same, that triggers the CEL for the P0420,
P0430 or both.
I can get the MINI CAT spacers, or try steel wool or stainless mesh in the
passenger side spacer before drilling the end out to 1/2"
So, that is where I am at now, P0430, after new cats, new sensors, and
from both sides having codes, to one side now.
Old 02-03-2020, 02:50 PM   #5
'10CamaroDude
I contacted the idiot, and he can't remember what he said what code it was. I
know it's P0430, but if it went from P0420 to P0430 after the spacers, then the FIX
is removing Bank 2 spacer... I will try it anyway, just in case.
