10-10-2019, 08:57 PM | #1 |
Drives: 2011 Camaro SS Join Date: May 2019
WOT switch
I'm installing a Nitrous Outlet plate kit. Trying to figure out the WOT switch. SO the mechanical switch they supply goes on the gas pedal ? Anyone have instructions on that ? There is an extra wire on the supplied throttle body harness. I would need a controller to use that from what i'm reading ?
2011 Camaro SS
Stainless Works LT's Rotofab CAI Tune 3.91 13.27- 107 mph @ 1200 ft and 90F |
10-10-2019, 09:10 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Strongly recommend getting one of these. Comes with instructions... wires to your tb and can set window to turn on and off so you don't blow your sh*t up.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-17-2019, 09:07 AM | #3 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Get a controller, window switch, with a tps sensor input. You will need to pull timing, install different spark plugs and more. Not sure which kit you have, but a mechanical switch is usually triggered by the linkage on a carburetor or the throttle cable/linkage. Don't skimp on doing it right. Call N.O. They are great at helping out and supplying info.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
10-17-2019, 06:31 PM | #4 |
Space Shuttle Aficionado
Does this still work well when mixing it with Nitrous Outlet products?
10-17-2019, 06:44 PM | #5 |
Yes
10-17-2019, 07:12 PM | #6 |
Hmm... much cheaper than the Nitrous Outlet window switch too.
How vital is running a controller?
10-17-2019, 07:23 PM | #7 |
Set it and forget it.... on at 2800 rpm, off at just under your redline
10-18-2019, 08:26 AM | #8 |
GrINned & JUICEd
Careful about how much you spray at 2800 rpm. For a single stage setup, best to use a progressive controller with correct initial percentage and ramp time, imo.
10-18-2019, 08:43 AM | #9 |
My set up was with only 75hp jets. It actually made 95 hp on the dyno. I did not have to pull any timing... not necessary to have a progressive on that small shot. My set up was conservative... just for the street. If you want more... for the track, then you will need to pull timing and most likely need a progressive controller.
10-18-2019, 08:45 AM | #10 | |
GrINned & JUICEd
Highly recommend using a controller and not just a push button or wot switch. A basic controller will only allow the nitrous system to operate only at wot and spray between certain rpm's. But to each there own.
10-18-2019, 12:03 PM | #11 | |
10-22-2019, 09:10 AM | #12 |
GrINned & JUICEd
Yes, imo. The reason: N2O jets spray a fixed amount of nitrous at all rpms. Exception, progressive or multi stage systems. A 100 shot sprays the same amount at 1000rpms as well at 6000 rpms. So at 1000 rpms, the cylinders are trying to ingest a lot more N2O per stroke, which will create a lot more power at that rpm. If it can't ingest all of it, it may backfire through the intake or damage the engine because of the high concentration of N2O going into the cylinders, potentially bending a rod, beat rod bearings or damaging a piston. For a 100 shot, I would change to a 1 step colder, nonprojective plug and pull 4 degrees. Install a new plug in #7 just before a wot spraying run. Do the correct steps to read the plug, such as minimal to no idle before or after the run, etc. Pull the plug and read it. The "line" on the ground strap will tell you if too little or too much timing. Nitrous Outlet rates their hp at the wheels. N2O speeds up the burning process, thus the need to pull timing. Or your flame front will hit your piston as it travels upwards, then bad things happen. How much timing depends on octane and how big of a shot. Pull 2 degrees for every 50 as a guideline. Then read the plug and adjust. This will get you very close to where you need to be. More fuel should be added while spraying. Your wideband lambda should be around .78. Plug reading and track time with minor adjustments will fine tune. Maintain your bottle pressure around 950lb for consistent results. Don't skimp on building your system. This was just some quick highlights.
