Old 05-17-2020, 03:40 PM   #1
Silveradoss573
Drives: Camaro 1LE
Buying a amplifier question
I'm gonna go ahead and upgrade the amp in my car. I found one but have a concern. Seller claims it's brand-new in the box as if I bought it brand new. The only thing is, he claims it was bench tested. What and why would a amp need bench tested?
Silveradoss573 is offline   Reply With Quote
Old 05-17-2020, 05:49 PM   #2
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Bench test usually just means that it was tested to make sure it works.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 05-17-2020, 05:58 PM   #3
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
I bought my sub amp used. Works great. I think the brand makes a big difference. Some companies build really good amps that will last.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 05-17-2020, 07:31 PM   #4
Silveradoss573
Drives: Camaro 1LE
It's a JL XD400/4v2 and $150.00 off from the $499.99 list price. Is it worth the gamble as there would be zero warranty?
Old 05-17-2020, 09:55 PM   #5
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
I have the exact same amp. I used it to replace the factory amp. I bought that one new. The used one I bought was a JL monoblock 600w for my sub amp that works great.
I think JL Audio is a safe bet, their amps are really durable and very reliable. $150 off is a great deal, I paid the $500. I recommend looking up Steve at Sub****p. He makes a factory amp replacement kit harness for for gen 5 Camaros that works perfectly and is easy to install.
Old 05-19-2020, 12:52 PM   #6
Silveradoss573
Drives: Camaro 1LE
I installed the GM Kicker self powered sub. The sub gets the signal from the driver's side rear 6x9. So I know I have to add the adapters from the fark kit to those. Will it affect the sub in anyway?
Old 05-19-2020, 09:51 PM   #7
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Not sure. I think the adapter from the FARK kit has to do with the 6x9 being a 3 way and running it as 2 way. It’s something like that. So, I don’t think the adapter will affect the signal as an output.
I think it might be better to run you me sub from the output that will be on your JL amp. That is how most people run a sub.
