Old 09-14-2020, 04:05 PM   #1
GK_2012_SS
GK_2012_SS's Avatar
Drives: 2012 Camaro LS3 2SS
SS Manual Transmission Question
Hey guys, I have a 2012 SS with manual transmission. Take a look at the photo with the arrow pointing to a "hole" in what I think is the clutch bell housing. First of all, what is it? And second, is it supposed to be capped/plugged?
Thanks
Z/28 Cold Air Intake; ARH 1 7/8 Long Tube Headers, High-flow Cats, X-Pipe; Borla ATAK; 160 Deg. Thermostat; Craven Tune
GK_2012_SS is offline   Reply With Quote
Old 09-14-2020, 05:55 PM   #2
steakmaker
steakmaker's Avatar
Drives: '10 Camaro SS,Jeep Commander Hemi
looks like it was plugged,especially because of the ring around the hole,I tried to look under my car but couldn't get under far enough ,someone will chime in.
steakmaker is offline   Reply With Quote
Old 09-14-2020, 05:59 PM   #3
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2013 2SS, 2015 LaCrosse, 2017 Z06
In the old(very old!) days there were clutch adjustment access holes.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 09-14-2020, 11:04 PM   #4
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 NPP BRM
Thanks
From that angle is looks like where there slave fitting should be, but it can't be that because you'd have no functioning clutch. It could be where the clutch bleeder valve should protrude from ...I'm assuming you're not the org owner and I'm gonna take a WAG that the prior owner installed some kind of aftermarket bleeder where the bleeder valve doesn't protrude
camguynj is offline   Reply With Quote
Old 09-15-2020, 10:45 AM   #5
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
That's just an inspection hole. The cap isn't a big deal, but yes, it was capped.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
BMR 1" lowering springs, trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified FULLY 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 09-15-2020, 01:07 PM   #6
camguynj
camguynj's Avatar
Never noticed an inspection hole on a TR6060. See this pic https://ls1tech.com/forums/attachmen...n-img_2913.jpg
This may not be the oem trans ?
Old 09-15-2020, 01:45 PM   #7
GK_2012_SS
GK_2012_SS's Avatar
Yes, I believe you are correct. Now to find the part number for the cap!
Old 09-15-2020, 03:04 PM   #8
GK_2012_SS
GK_2012_SS's Avatar
UPDATE: My local Chevy dealer tells me that it is a clutch housing inspection/moisture drain hole and that there is no cap or plug from the factory.
Old 09-15-2020, 03:25 PM   #9
camguynj
camguynj's Avatar
Intriguing! Sure don't see it in the TR6060 pic. Maybe it's just the angle of your pic. Where abouts is it on the tran ...top, bottom, side?
Old 09-15-2020, 05:50 PM   #10
theflea42
#938 of 1524
Drives: 2013 Hot Wheels Edition Camaro
I got my car up on ramps so I could crawl underneath to give this area a looksee. There is a star headed bolt up in this hole. Nothing else, just that bolt.
theflea42 is offline   Reply With Quote
Old 09-16-2020, 09:38 AM   #11
GK_2012_SS
GK_2012_SS's Avatar
Thanks for looking. So I take it yours did not have a cap/plug either, correct?
Old 09-16-2020, 09:47 AM   #12
GK_2012_SS
GK_2012_SS's Avatar
Got this photo from George-CZ showing no cap/plug.
Old 09-16-2020, 06:37 PM   #13
theflea42
#938 of 1524
Yep, no cap or plug in there. No signs of one being there before either.
Old 09-20-2020, 08:12 AM   #14
camguynj
camguynj's Avatar
Must be a weight reduction option on select models
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
