05-23-2021, 12:35 AM | #1 |
Drives: 2013 CHEVROLET ZL1 Join Date: May 2019
Display problem
Has anyone lost a info reading on their digital display ?
Went for a ride today and the tire pressure info screen does not come up on the display has you cycle through the display options . |
05-23-2021, 04:40 AM | #2 |
It don’t come easy.
Are you using the menu button to cycle between all the options? Just a thought.
05-23-2021, 08:29 AM | #3 |
Drives: 2013 AGM ZL1, '70 Chevelle 454 Join Date: Apr 2019
Shortly after purchasing my car the hvac controls stopped working so I disconnected the battery for about an hour. Reconnected it and got my hvac controls back plus a few other items in the HUD display that I didn't realize were missing since the car was new to me. I realize your issue is in the DIC but it might be worth a try, doesn't cost much and isn't difficult to do.
05-24-2021, 06:36 PM | #4 |
Drives: ZL1 Join Date: May 2021
Your right about the battery reset . Removed ground waited a while and reconnected the ground cable . The tire pressure display was back . Of course needed to reset the tire pressure sensors . All is well . Should of posted this to the forum earlier . My apologies .
05-24-2021, 07:02 PM | #5 | |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
05-26-2021, 09:27 PM | #6 |
For a while 2SSRS but access got snafu'ed with a e-mail problem . Choosing a new name ended up being easier than going back and forth with mod's :-)
