Old 05-27-2020, 08:18 AM   #1
theflea42
#938 of 1524
Drives: 2013 Hot Wheels Edition Camaro
Torn leather seat
I found a tear in my drivers side seat! I'm not sure when it happened though. It wasn't like that when I put it up for the winter.
Is there any way to fix this?
theflea42 is offline   Reply With Quote
Old 05-27-2020, 09:10 AM   #2
gtstorey
I was able to greatly improve a torn motorcycle seat years ago with on of the vinyl/leather repair kits years ago but it wasn't perfect. I've seen pro's using something similar on some of the car shows on TV.
About the only other option I could see would be to pull the cover and have the torn panel replaced.
gtstorey is online now   Reply With Quote
Old 05-27-2020, 09:16 AM   #3
fhrex
fhrex's Avatar
Drives: 2011 Camaro 2LT/RS
I had a very similar tear in my passenger seat cushion cover when I bought my car. A local guy with mobile service repaired it to the point that I have to really look close to tell that anything ever happened. Don't know what he uses, but he's good. Of course, I'm in Virginia, but I would think that there would be someone in your area that performs the same type of service.
fhrex is offline   Reply With Quote
Old 05-27-2020, 12:51 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
This can be repaired. I repaired a small triangular hole in a leather jacket using Loctite vinyl, fabric & plastic flexible adhesive.
Given the size of your tear, you will need a backing material to add strength, which will require pulling off the cover. A pro should be able to do this easily.
Rock-It Man is offline   Reply With Quote
Old 05-27-2020, 06:40 PM   #5
ron123
ron123's Avatar
Drives: 2014 2SS/RS
My 2014 seat ripped when under warranty in the same location; Chevrolet replaced the seat cover and did a perfect job. In my case I was using the seat heater and think the leather/backing overheated and lead to the split.
The leather is very thin, perforation breathing holes reduce the strength, and high heat may have been the final straw. The backing material on the leather I think provides most of the strength.
Here is my thread on this topic: https://www.camaro5.com/forums/showthread.php?t=480946
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 05-28-2020, 07:06 AM   #6
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '19 Corvette Stingray
YES it can....actually you can replace the cover on the seat. I know, I had someone break into my car and in the process tore my leather seat....the repair shop went and bought a new cover (from GM) and replaced it. SO, it can be done.
Old 05-28-2020, 07:29 AM   #7
gtstorey
If a replacement Hot Wheels cover is available that is probably the way to go.
Old 05-29-2020, 12:11 AM   #8
theflea42
#938 of 1524
I'm going to call a dealer tomorrow and see if I can get a hot wheels cover. I'll hafta remove the cover to fix it anyway. This kinda sucks!!
Old 05-29-2020, 07:26 AM   #9
gtstorey
I think the repair kits typically don't require removal.
Old 05-29-2020, 08:25 AM   #10
myold88
myold88's Avatar
It would be interesting see if that cover is still available from GM after 7 yeas.
Old 05-29-2020, 10:35 AM   #11
theflea42
#938 of 1524
Well, I just found out you can still get the seat cover - its $500.
Old 05-29-2020, 01:27 PM   #12
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: 2019 Hyundai Santa Fe Ultimate
Baldman is offline   Reply With Quote
Old 05-29-2020, 01:50 PM   #13
Silveradoss573
Drives: 2015 Camaro 1LE
Katzkin front and rear complete leather set is less than $700.00. If mine rip or wear out, Katzkin's are going in. Quality is night and day over the stock pleather.
Silveradoss573 is offline   Reply With Quote
Old 05-29-2020, 10:40 PM   #14
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
check out an upholstery shop locally they might surprise you ........
Cyber/Orange10 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
