Emblempros
Old 05-28-2020, 10:42 PM   #1
Flannel-On-A-Camel
Flannel-On-A-Camel's Avatar
Drives: 15 RH Z/28 #185, Hennessey #006
Understeer in Relation to Tire Size
Alright, y'all. I'm calling upon the collective expertise and experience of everyone here once more. I've been tearing this forum apart for an answer, but I haven't quite got one that I'm totally satisfied with.
So, most of us know that a staggered set of tires, say 305's in the front and 325's in the rear, will cause understeer. However, just "understeer" is difficult to quantify. Those with experience with this set up, especially if you track your rig, what are your thoughts? If you drive your Z at 8/10th's, is is noticeable? How about around town?
Thanks in advance! Also, pictures are more than welcome. Square 325 set up pictures are also cool!
Flannel-On-A-Camel is offline   Reply With Quote
Old 05-29-2020, 12:29 AM   #2
'10CamaroDude
Drives: 2010 Camaro LS
Fatter tires in the rear can produce noticeable under-steer. The more rear-biased the
more under-steer. The front tires lose traction first with wider ones on the back,
which causes under-steer.
However alignment, spring rate, sway-bars and very importantly, driving technique
also play a big role. So, if you want the larger tires in back, then modify the
suspension to compensate.
'10CamaroDude is offline   Reply With Quote
Old 05-29-2020, 09:41 AM   #3
LateBrakeU2
Drives: 15 SIM Z,1114,RH Z 1066,20 SS1LE RG
Most folks wouldn't notice the difference , certainly at civilized speed. At 8/10ths it would be, to some,but you can dial it out with the pedal on the right The gen 6 1LE's and ZL1LE's all come with a smaller contact patch up front, and they are well balanced cars right out of the box. YMMV
LateBrakeU2 is offline   Reply With Quote
Old 05-29-2020, 11:10 AM   #4
Shoupaloop
Drives: 2015 Z28
I didn't notice much with a staggered set-up. The rims are different widths anyway which will change the specs of the tire anyway. The difference between a 305/325 GY 3R is not much as say a 305/325 Trofeo.
Shoupaloop is offline   Reply With Quote
Old 05-29-2020, 12:28 PM   #5
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2014 Camaro 1SS RS SIM
Going from a staggered setup to a square setup makes a huge difference, definitely felt the difference in the canyons.
2014 SS - BTR Stg 2 Cammed L99 1SS/RS FBO - "AleSSandra"
SSEssence is offline   Reply With Quote
Old 05-29-2020, 07:13 PM   #6
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
I think you would need to be a professional driver to notice any measurable difference. If you notice understeer from a 305 to 325 on the street you probably shouldn’t be on the street.
Also a Trofeo to something like an RE11 street tire can’t be compared, staggered or not.
From what I read they did a square setup with Trofeos because it tweaked a little bit more out on the N’Ring.
69L48Z27 is offline   Reply With Quote
Old 05-29-2020, 09:00 PM   #7
joelster
Drives: '94 Z28+ '15 Z/28
There really isn't a lot of "expertise" on this forum with regards to racing and REALLY pushing these cars. There's a lot of great guys in here but most of them don't use the car as intended, and there's nothing wrong with that, I'm just saying......
Any "street" evaluation will be flawed because streets aren't prepped, the tires aren't up to temp, pressures could be wrong, etc, etc.
I can give you lots of feedback on real world testing of 305's square when pushing hard from 20mph-60mph. But that's with a Potenza RE-71R, not a Trofeo. Not sure if other tires will behave different. My car has substantially more front end grip than it does in the rear, period. Granted a lot of times when I'm turning the wheel, I'm standing on the brakes, which drives them down, but even in a fast-ish slalom, the tail will step out before the front will push. I can get it to push in certain situations, but mostly the rear is the end that misbehaves.
'94 Z28, 414" LT1, 10.15 at 133.65 N/A pump gas
'15 Z/28 Red Hot, A/C
joelster is offline   Reply With Quote
Old 06-09-2020, 10:27 AM   #8
Matty Ice
Matty Ice's Avatar
Drives: 2015 SS/RS 1LE
I have tried to remove the small amount of under-steer my 1le had built in. I have changed many things, it's pretty much a Z28 lite now. Just like Joelster says, my car has more grip in the front than the rear. It will push the front tires on the street, it is on colder tires, a tight very slow turn with moderate acceleration, like a u turn or something similar. If I am pushing the car hard around 90deg corners I will get a nice neutral slide as the front will break the same as the rear and with a little more throttle the rear will step out rotating the car a little more. If I went with a 305 in the rear I think I would lose the ability of rotating the car with the throttle.
Matty Ice is offline   Reply With Quote
Old 06-10-2020, 02:40 PM   #9
quickdrraw
quickdrraw's Avatar
Drives: 2015 Z/28
I have run many tire setups on this car, although not staggered, I still adjusted alignment for each tire setup. My RE11 rain track tires need the rear loosened slightly, while the trofeo's handled the stock track alignment well (needed slightly more camber than suggested), and I just got some 315 R888Rs that will need some refinement at the track too. Tire pressure, suspension setup (specifically stiffness of sway bar), alignment, driving technique all play a factor as most people have stated. I had Randy Pobst in my endurance car in January that was tail happy, he completely disconnected the rear sway bar for his driving technique. We were within half a second of each other at Laguna Seca, the sway bar gave him an extra .2 seconds.
2017 Silverado Z71 Black S/C - 520rwhp/ 556rwtq
2015 Camaro Z/28 Black - 500rwhp/480rwtq
Sold:
2010 Camaro 1SS/RS Rally Yellow 435rwhp/425rwtq
quickdrraw is offline   Reply With Quote
Old 07-06-2020, 09:22 PM   #10
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631
Why dont you just run four 325s? They fit with enough room to spare front and back. The Michelin Pilot Cup2s allow the car to corner just like the older trofeo-rs .... they corner like a scalded dog...
And at 12 to -12.5 wide I get comments at every cruise in
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631
Toy 2 '09 CGM Z06 3LZ
My DD: '17 Ford Mustang GT
Her DD: '14 F150 Ecoboost 3.5
The_Raging_Bull is offline   Reply With Quote
Old 07-06-2020, 09:59 PM   #11
Flannel-On-A-Camel
I thought about it. I was worried the fronts might bulge over the rim too much. Do you have a few pictures of your set up that you can share?
Old 07-06-2020, 10:36 PM   #12
spyderbuddy
spyderbuddy's Avatar
so why do i experience more oversteer in my car vs understeer
I have a 2010 V6 2lt Auto with 275 45 20"s on Front and 315 35 20's on back
if i push it hard the back breaks loose first, which of course then i steer with the throttle
I have driven it hard and the front does not brake loose first.
I been driving the car for ten years
TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
spyderbuddy is online now   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
