Old 05-12-2015, 06:01 PM   #1
Sidecardog1
Sidecardog1's Avatar
Drives: 2015 2SS, 1LE, Dual Mode, Black
Ramps for 1LE
OK, so I am soon to run out of my "free" oil changes that my dealership provided me with the purchase of the car. I would like to do my own oil changes and also for some other underneath work. I tried buying a set of ramps at an auto store and they let me bring them out to the parking lot to try for clearance. The ramp runs into the front splitter before the low end of the ramp runs into the wheel because of the too steep angle. I have seen some large & costly ramp systems that come apart in pieces so you can get the ramp out of your way & just leave the section holding up the wheel while you do your work.
Anyone have a recommendation of what ramps work for your 1LE ? Call me crazy but I like to keep the car out of the dealership as much as possible. So I would appreciate any suggestions that you have. Thanks
Sidecardog1 is offline   Reply With Quote
Old 05-12-2015, 06:09 PM   #2
mbowen89
Drives: 2015 CRT 2SS/RS 1LE
What happens if you put an inch or two board in front of the ramps so it's up a little higher by the time it hits the ramps?
What auto store did you go to and what did you try?
mbowen89 is offline   Reply With Quote
Old 05-12-2015, 06:16 PM   #3
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
What he said. I don't have a 1LE but I had the same issue with ramps for my SS. I use 2 boards about 1.5" thick to drive up on before the ramps and it clears just fine.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 05-12-2015, 06:28 PM   #4
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Ditto I use 2x4s drive up on those then the ramps.
BigBlock69RS is offline   Reply With Quote
Old 05-12-2015, 07:07 PM   #5
Bizaro
Drives: 2015 Redhot 1LE
use 4 jacks
Bizaro is offline   Reply With Quote
Old 05-12-2015, 07:15 PM   #6
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Racer Ramps.
www.raceramps.com
Old 05-12-2015, 07:35 PM   #7
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
Originally Posted by Dropspeed View Post
Racer Ramps.
www.raceramps.com
+1 light weight and come apart to slide in between the wheels. If its a big project I will put a long 2x12 under the race ramps for some extra room.
Stephen Colbert: “Reality has a well-known liberal bias.”
Old 05-12-2015, 07:58 PM   #8
backeddy
Banned
Drives: 2011 Boxster Spyder (best car ever)
use 4 jacks
and make sure you chock the wheels with the jack stands.....they are for pussies anyhow.
Seriously just get race ramps or 2x4s
backeddy is offline   Reply With Quote
Old 05-12-2015, 08:24 PM   #9
Wollmank
Drives: 2014 Camaro 2SS/RS 1LE AGM
I was under the impression all camaros had free 2 year free oil changes. Not from dealer but gm. Mine came with 2 year maintenance
Wollmank is offline   Reply With Quote
Old 05-12-2015, 10:15 PM   #10
Sidecardog1
Yes, that is what I meant, the 2 year maintenance which I was told equates to 4 oil changes. Thanks all for the ideas, I will do some looking at the racer ramps. The store I went to was the local Advance Auto, they are always accommodating there, just their ramps didn't work. Appreciate the input.
Old 05-12-2015, 10:23 PM   #11
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Race ramps
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 05-13-2015, 08:38 AM   #12
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
Race ramps
Old 05-13-2015, 09:30 AM   #13
SASQUATCHelvis
Drives: 2014 Camaro SS 1LE
I use 2x4s, though race ramps would probably be a worthwhile investment.
SASQUATCHelvis is offline   Reply With Quote
Old 05-13-2015, 09:52 AM   #14
Balue
Balue's Avatar
Drives: 2013 SW 2SS/1LE
Just got my Raceramps a couple weeks ago and love them. Made loading the trailer worry free and with the 10inch rise service extensions getting under her will be no problem. I ordered the following ones.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Balue is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
