01-17-2020, 11:30 PM | #1 |
Drives: 2010 Chevrolet Camaro SS Join Date: Sep 2019
So I went with the BTR Nightfury
I have the Nightfury cam kit in the trunk of my car, as well as a new trans cooler. The VVT delete kit to convert the L99 to an LS3 is coming in the mail along with the 6l80 3200 stall converter. I also have LS9 injectors and a Flexfuel kit.
Should I also get an intake manifold, or would the stock hold up to a cam like that? What would I need to install to make this a better running engine? Side note: That crossover Edelbrock intake manifold sure has a nice look...
2010 Camaro 2SS/RS:
Cyber gray matte wrap, Danti Lambo style louvers, Granatelli Pro-stock look wing B&M transcooler, Mishimoto oil cooler, Mishimoto catchcan, Borla/Pypebomb axle back L99 to LS3 conversion, Vararam ram air intake, BTR Nightfury cam, Johnson lifters, LS7 injectors, Circle D 3200 stall converter, Kooks LT headers, Custom X-pipe |
01-17-2020, 11:42 PM | #2 |
Drives: 5th Gen L99 Join Date: Nov 2017
You’ll be fine with the stock intake manifold. Cordes performance racing in Tempe is a great shop. They can do the install and tune, or only the tune whatever your preference. Joe is a great guy.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
01-17-2020, 11:46 PM | #3 |
Drives: 2014 2SS/RS Join Date: Jan 2018
Hard to beat the flow of the LS3 intake. Best bet after that is to have it Rod Modded. Everything else offers minimal gains for the huge expense.
2014 2SS/RS LS3/M6
01-18-2020, 08:37 AM | #4 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Stock intake flows well. Just like others said, GPI modded one flows a wee bit better. Like the stock one it still drops off in power around 6600rpms. For a street car that is fine. You wont lose low end compared to switching to a different manifold, which will move the powerband to the right.
Just do the valvetrain right. Good springs and caged needle bearings or trunnion upgrade.
More to come. Last edited by Black_SS10; 01-18-2020 at 12:43 PM. |
01-18-2020, 09:23 AM | #5 |
USA-1
Why are you deleting VVT? That's going backwards...
Off that topic, get the GPI ported/rod modded intake manifold. Also, did you grab an underdrive pulley? With the manifold and pulley you are looking at around a 20 hp gain.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
01-18-2020, 10:50 AM | #6 |
Chill bro, the LS3 is a great motor also. VVT or not the car will be awesome after a cam swap.
01-18-2020, 12:00 PM | #7 |
Alright thanks guys, I was kinda worried about the stock intake and all, the throttle body should be ok too then.
And I have to delete VVT to make the engine an LS3, but the torque converter will help with the loss of torque when I take VVT out.
2010 Camaro 2SS/RS:
01-18-2020, 12:23 PM | #8 |
That’s what I told myself too.
01-18-2020, 12:45 PM | #9 | |
SomeguyK
Just get yourself a good torque converter, stall wise. One that matches the engine powerband.
More to come. |
01-18-2020, 02:34 PM | #10 |
You have any difference in performance?
For sure man...because I really like the look of the Edelbrock cross ram intake, lol.
2010 Camaro 2SS/RS:
01-18-2020, 03:22 PM | #11 |
USA-1
OP, what's the reasoning for taking out the VVT to be an LS3? I ask because I've seen too many people go that route who don't really need to. From what I've read, if you are building a car for the strip, take the VVT out, if not (and for probably most people on here), stick with the VVT!
I mean, there are guy's on this forum whose VVT cars are in the high 10's...
01-18-2020, 05:05 PM | #12 | |
2010 Camaro 2SS/RS:
01-18-2020, 06:46 PM | #13 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
He's planning for boost. He talked about it in another thread. VVT not necessary for his plans.
01-19-2020, 08:58 AM | #14 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Stock intake is great for performance. I’m changing it for a different look- to be different. But their are plenty of 1000+ hp Camaros on the stock intake/TB.
