01-07-2017, 09:27 AM | #1 |
Drives: LSx Powered Join Date: Oct 2009
HorsePowerAddicts DE New Years Sale on Cam packages starting at $1750
HPA is cutting the prices down on our already low packages to kick off the new year. We have a ton of 5th gens and even 4th gens come through the shop already without much advertising. Now for 2017 we are looking to make sure everyone in the Camaro community knows we are a great one stop shop in Delaware for performance work and tuning.
Contact us today for your GM performance needs!! We would love to help on your next project. 5th Gen Camaro Cam Special Includes: -Any Comp Cams Camshaft(Custom grind or off the shelf) -BTR Dual .660 Valve Spring kit with lightweight Retainers, new valve seals, seats, and locks -BTR Hardened .080 wall Pushrods -3 bolt cam gear -ARP cam bolts -New GM Crank Bolt -New front cover gasket, seal, and water pump gaskets -NGK Spark Plugs -Oil change (Mobil One oil, and AcDelco oil filter) -Top off all fluids -Professional Installation -Full Dyno and street tuning with HPTuners -Dyno printouts Price: LS3= $1750 LSA= $1950 *Melling oil pump and HD timing chain optional. L99 We did not forget about the L99 Camaros out there wanting a cam too. For the L99's we take the standard package above and add on a DOD/VVT delete. -LS3 Timing cover -GM LS7 lifter and trays -GM MLS headgaskets -GM headbolt set -LS3 valley cover -GM exhaust gaskets -Add on labor to the cam package for DOD delete Total Price= $3250 Add on Brand new GM CNC ported cylinder heads for $1300 during DOD delete. Everything Is discounted for this deal (labor, tuning and fabrication) Contact us for all services, tuning and installations Call or email to set everything up. Horsepoweraddicts@gmail.com (302)838-2188 horsepoweraddicts.net |
02-02-2017, 08:17 AM | #2 |
02-22-2017, 04:58 PM | #3 |
Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS Join Date: Oct 2016
Do you offer BTR cams?
2017 C7 Z06
2013-ZL1 2017 HELLCAT SOLD 2019 HELLCAT REDEYE WB 69-Z28, LSA SWAP, T56 MAGNUM 71-CHEVELLE SS, 496 STROKER TH400 |
02-22-2017, 05:14 PM | #4 |
