#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
Old 03-26-2020, 12:04 PM   #1
Pmcmath
Pmcmath's Avatar
Drives: 2019 Camaro ZL1
Drag pack for 2019 ZL1
Has anyone put wheels and tires all the way around on their 19 ZL1? Having quite the time getting specs and need to figure this out. I currently have a 20inch wheel with MT Et Street SS on the rear. Racing street points here soon once this mess goes away so want to be right when it starts. Any help is much appreciated....would even accept a rear tire and wheel option at this time.
Pmcmath is offline   Reply With Quote
Old 03-26-2020, 02:29 PM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I believe you can run a 18x5 front and 17x10 rear and run a 305/45/17 drag radial or 28" slick.
https://www.camaro6.com/forums/showthread.php?t=488498
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 03-26-2020, 04:53 PM   #3
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
That is what we run in the rear on Weld Wheels. Still need to fit the fronts. will advise.
Stefano is offline   Reply With Quote
Old 03-26-2020, 05:06 PM   #4
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Drives: 2017 Hyper Blue A10 ZL1
I have a 17x10.5 rear with a +32 offset. Would really prefer around a +38 offset, but it works with the shorter tire I'm currently running.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA
TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
17CamaroZL1 is offline   Reply With Quote
Old 03-26-2020, 08:51 PM   #5
Pmcmath
Pmcmath's Avatar
Thanks for the replies. That's a start for sure....it ran a 7.09 in the 1/8 last time I was out a few weekends ago but now everything is halted here locally. I'm wondering if the lighter wheels will help some....
Old 03-27-2020, 07:31 AM   #6
17CamaroZL1
What's done to the car? That's a solid time.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 03-27-2020, 09:17 AM   #7
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
The lighter wheels will help. The average stock wheel and tire will be over 60 lbs each. You'll save the most on the fronts as the drag radials are fairly heavy but the wheels will be lighter unless you choose a bead lock for the rear. I run a 17x10.5 Race Star rear which are not bead locks with 305 45 17 MT and use a Permatex hightac sealant to keep them from spinning on the wheel and they will if you don't seal them.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 03-27-2020, 06:36 PM   #8
Pmcmath
Pmcmath's Avatar
Just an cold air intake and Corsa exhaust. I was running a Copo at the Loose Rocker so held a few numbers to run him out the back but he went red so ran it out. .
Old 03-27-2020, 06:39 PM   #9
Pmcmath
Pmcmath's Avatar
I ordered some last night...17x10's and 18x5's on front with 305 45 17 MT Et Street SS on back and 28x6x18 for fronts. At least now I will be matched around.
Old 04-02-2020, 06:22 PM   #10
Pmcmath
Pmcmath's Avatar
Ok heads up for ZL1 owners. The VMS wheels will not fit a 2019. They are within a business card distance of the brake caliper which to me seems tight?? I dont like them being that close to my calipers so now I guess I'll return them to where they came from.
Old 04-05-2020, 10:55 AM   #11
Omega Doom
Drives: 2017 Chevy Camaro 2SS
yes just received mine a few days ago and went to put them on last night and yes they are tight and hell 1 wheel didnt even fit so i need to call them tomorrow to see what they will do pisses me off after dropping over 1k on brand new wheels that 1 doesnt fit and reached out to them via email but no response yet probably because of the weekend though
Omega Doom is offline   Reply With Quote
Old 04-05-2020, 10:57 AM   #12
Omega Doom
a buddy of mine who also has a 2019 Zl1 bought the F14s from summit direct fit just in case you wanted to know
Old 04-09-2020, 04:17 PM   #13
supersportss
Drives: 2019 SS
https://1320wheels-com.3dcartstores....5-_p_1000.html
supersportss is offline   Reply With Quote
Old 04-09-2020, 05:48 PM   #14
Stefano
Stefano's Avatar
I fit the Forgestar D5s on the front / 18"x5” and they clear the ZL1 calipers and are good for 2017,2018,2019,2020 SS and ZL1.
