#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
Old 09-01-2023, 01:06 AM   #1
KL01
Drives: Chevy Camaro 2SS
Built SS 800whp 1/4 time guess.
I have a built 19 SS with A10 tranny that I just got built about a month ago. I am taking it to the track next weekend and wanted to see what kind of times I should expect. Tranny is tuned/ D1X on 15psi/ meth/ BTR intake/ lt4 fuel system. I will be rolling on 20s 1le with 555r2 in the rear. Like stated, I am 800whp on pump with meth, 890whp with C16.
2019 2SS D1X/CAM/METH/DROP-INS 800whp on 93/ 890whp/670tq C16
KL01 is offline   Reply With Quote
Old 09-01-2023, 07:07 AM   #2
cjperformance
cjperformance's Avatar
Drives: 2017 Camaro SS 50th Anniversary
Under ideal conditions, mid-high 9s at mid 140s? If i had to put a number on it 9.7@143?
Thats a barely educated guess. I think 700 whp gets you dipping in the high 9s at low 140s, and 1000whp gets you into middle 9s (around 9.4 to 9.6 or so)....
Now lets let the folks who ACTUALLY know stuff talk
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
cjperformance is offline   Reply With Quote
Old 09-01-2023, 07:09 AM   #3
cjperformance
Just realized you have a D1X... do you have a stall conv? Otherwise, you are going to have to take a tenth or two off i think.
Old 09-01-2023, 08:07 AM   #4
jlaudio11
jlaudio11's Avatar
On 20's and no mention of converter, I'm saying mid to low 10's in the 140's mph.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels
1.45 4.01 6.07@120.74 9.28@153.43
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild
jlaudio11 is offline   Reply With Quote
Old 09-01-2023, 08:18 AM   #5
rcoe
rcoe's Avatar
Drives: 2016 Camaro SS
I would say mid 10's, betting traction is going to be an issue.
I have learned from experience having the power to run 9's on paper is not the same as actually putting down that power effectively. Though with the D1x and no converter it will not hit as hard off the line so you might not have the traction issues I have.
Good luck.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods
BTR stage 3 cam - Circle D converter
American Racing headers - Borla S-type
rcoe is offline   Reply With Quote
Old 09-01-2023, 10:00 AM   #6
wnta1ss
Drives: 2017 Camaro 1SS
rcoe has a very good point, dyno sheet saying '9-second car' does not translate to 9-sec timeslips in MANY cases. SO many times I have seen cars run slower or even much slower ETs than they should. Setup and driving technique need to be sorted out if quick ETs are desired.
My suggestion is to have fun, and try to learn what works for your car. Tech requirements mean that you should bring a Snell 2015+ Helmet and an SFI 3.2A/1 race jacket. Helmet is for running under 14sec, and SFI jacket is for adding a supercharger (also required under 11.5sec), these are NHRA tech requirements. Not sure how your tech guys will be, but I have seen locally a driver who had installed a Procharger on a Coyote stuck in tech, and they would not pass him until he was able to borrow a jacket.
wnta1ss is offline   Reply With Quote
Old 09-01-2023, 11:30 AM   #7
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
10.2 - 10.3 @ 143
You won't be able to get out of the hole, at all, unless you are the stig
You have the power, but none of the other stuff that makes for an efficient ET.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 09-01-2023, 01:56 PM   #8
KL01
I seen cars really moving at the track and most not having jackets. Sometimes running with no helmets. I always wore mine but don't have a jacket. Next upgrade will be drag pack, maybe stall converter depending on how much I want to chase 9s. I have seen zl1 do 9s with just headers, intake and E.
Old 09-02-2023, 06:26 AM   #9
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Without a converter and running a ProCharger I'd say 10.40@144. My Camaro makes 707 and ran 9.80@142.96 but its a Maggie with THPSI port injection and it doesn't need a converter to launch as boost is instant. My 16ss with a 2650 with over 850 rwhp ran 9.41@147 but once again with a PD blower and instant boost, with the right stall converter mid 9s should be achievable but not on a 20" drag radial or street tire. Gonna have to go to a 17" drag radail or slick
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 09-02-2023, 06:29 AM   #10
laynlo15
laynlo15's Avatar
Our track is an NHRA facility and I had to get an NHRA license this year to run there with my Camaro. I have the correct helmet, one layer jacket and pants. No cage required down to 9.00 with the new NHRA rules for 2014 and new vehicles.
Old 09-02-2023, 07:02 AM   #11
laynlo15
laynlo15's Avatar
I just went back and looked at my 9.80 pass and I was at full boost (177 kpa) in just under 3/4 second on the launch. Wish someone would post a Centri with no converter for a comparison, that would be interesting or even with a converter. Not a dragy, but track pass.
Old 09-02-2023, 07:14 AM   #12
laynlo15
laynlo15's Avatar
Originally Posted by danhr View Post
10.2 - 10.3 @ 143
Yours is a great example of what it takes to get in the mid 9s as far as supporting mods. You Camaro hauls ass and would run right there with my old 16ss.
What cam are you running?
Old 09-02-2023, 07:41 AM   #13
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Only responding because Dan doesn't post here much...I believe his time in sig was with the stock long block and cam.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 09-02-2023, 09:52 AM   #14
laynlo15
laynlo15's Avatar
Didn't see the cam, he's got a good running ride for sure. Brett seems to tune those ProChargers as well as anyone. I know you have some fast ones out there also.
