02-06-2024, 08:20 AM | #1 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Not there yet, but a new PB
In case some haven't seen it on other social platforms, we made some ET improvements a couple weeks back. The plan was to make the final push into the 7's at Cadillac Attack but had a head gasket issue due to freezing water.
But, despite that, progress is good and we'll try again in a few weeks, hopefully before the hot temps set in. If you take the first pass where I messed up the launch and merge it with the next one where we had either belt and/or trans/converter issues (data log is corrupt), it is reasonable to believe the car has at least 7.80's in it. The throttle body is actually closing to 55% briefly before the 1/8 still, so we need to continue to work with Nick Williams on that. It doesn't appear to be what will stop us from the goal, so it is on the back burner at the moment. Brief recap on the build - 427ci LT, Kong ported Maggie 2650R, +30 DI injectors, Big Bore pump, Fore triple in tank, THP PI kit (Holley controlling), Pure Drivetrain Solutions 10L90, stock mag ride, stock springs, and stock converter. Built by Vengeance Racing and tuned by Branden Leeb at Elite Tuned.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
02-06-2024, 09:04 AM | #2 |
Thats Impressive with stock suspension! I spent a fortune on shocks and struts and then I see this! lol You are sniffing the 7's! You will get it!
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
02-06-2024, 09:28 AM | #3 |
The Poe Poe
Drives: 17 911 Turbo S, 23' 2SS1LE, 06 S2K Join Date: Dec 2021
Outstanding!
Another local Metra ATL guy here.
2017 Porsche 911 Turbo S - GT Silver
2023 2SS 1LE - 6MT - Sharkskin 2006 Supercharged Honda S2K-Silverstone Metallic 2016 RAM Mega Cab 4x4 Diesel - Silver |
02-06-2024, 11:03 AM | #4 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Great work as always, Jason. You’re right there and 7’s are definitely in reach. Congrats!
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
02-06-2024, 11:09 AM | #5 | |
Drives: '20 ZLE Join Date: Jun 2020
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. |
02-06-2024, 11:43 AM | #6 |
2018 ZL1-NFG-A10
02-06-2024, 01:24 PM | #7 | |||
