#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
Old 03-24-2024, 05:54 PM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
How much gas in the ZL1 tank?
How much gas do you want in the tank at the starting line? 2-3 gal.?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is online now   Reply With Quote
Old 03-24-2024, 09:38 PM   #2
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
I have the Fore system so we always run it at least 3/4 tank so it doesn’t cavitate, but with the stock pump I would run it at 1/4 tank to save weight.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 03-25-2024, 07:57 PM   #3
Badmojo
aka BeastZL1
Badmojo's Avatar
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra
I would recommend no less than 1/4 a tank, which is 4.75 gallons. I've had fuel starvation issues on the road course (lateral G) with less.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Badmojo is offline   Reply With Quote
Old 03-28-2024, 08:42 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
There's no need to create a new thread for this question:
I use 1st gear delete, so in the water box, can I start the tires spinning in 2nd and quicklyshift to 3rd w/o endangering clutches? Using MT ET Street R 325/15
'20 ZL1 1LE A10,
