Old 10-11-2018, 05:18 AM   #1
Level300
Drives: 2015 Black rs/ss/1le
Dash pad adhesive discoloration problem
Hi. It looks like my car had some sort of dash pad installed before I bought it.
When there is a change of temp (hot day, ac turned on) the spots where the adhesive was before start appearing as rectangles. It’s very noticeable and you can see all the spots where the glue pads were placed. Otherwise, the dash looks normal and uniform.
I’ve used McGuire’s vinyl cleaner on the dash and on the surface it feels clean, no sticky residue. I suspect the adhesive residue seeped into the vinyl and is affected by temperature change.
Has anyone run into this before? Anyone have any suggestions on how to fix this? Thanks!
Lol dash pads. Ruin the thing you’re trying to protect.
Level300 is offline   Reply With Quote
Old 10-12-2018, 08:49 PM   #2
KirkH
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD
Try in this order:
15% isopropyl alcohol solution
turtle wax glue and label remover
goo gone auto
goo gone regular
KirkH is offline   Reply With Quote
Old 10-14-2018, 08:39 PM   #3
Level300
Originally Posted by KirkH View Post
Try in this order:
goo gone auto
goo gone regular
Thanks.I'll give this a shot.
Old 10-14-2018, 10:42 PM   #4
gringo
gringo's Avatar
Drives: Camaro V6
You may be out of luck. The adhesive melts into the dash pad and reacts with the material changing the texture. You might have to either live with it or get a whole new $$$$ dash.
gringo is offline   Reply With Quote
Old 12-10-2018, 01:22 AM   #5
rdanzel
Drives: 2010
Give 3m adhesive remover a try. Don't use lacquer thinner or a strong solvent because it has a tendency to dissolve the surface of the vinyl.
rdanzel is offline   Reply With Quote
