07-03-2018, 08:28 AM | #1 |
Drives: 2013 Camaro SS Join Date: Feb 2017
Drag radials
Are drag radials better than street tires as far as wheel hop and breaking parts with stock suspension. A guy told me that wheel hop would be worse with drag radial is that true?
07-03-2018, 08:56 AM | #2 |
Drives: 2013 ZL1 Convertible Join Date: Oct 2013
Wheel hop is usually a result of axle twist or suspension deflection. Drag radials could definitely make it worse.
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15 FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's New times to come with E85 2016 2SS Auto - Hyper Blue Metallic Roto-Fab CAI |
07-03-2018, 09:08 AM | #3 |
Drives: 2011 1ss Join Date: Jun 2017
Trailing arms/rods/bushings and then go to drag radials
07-03-2018, 10:07 AM | #4 |
Once you realize why wheel hop happens you will answer your own question. However you will get wheel hop with both if you are on stock suspension bushings and dont have all the goodies to stop it.
