12-04-2023, 02:38 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Jun 2020
Rear shocks magnetic ride
Hi
A couple of weeks ago I noticed my suspension a bit rough mainly at the rear passenger side, too much bouncing, also some vibration. I change settings (T to Sport back and forth) but I don't notice any changes. Today I removed the rear passenger wheel looking for damaged trail/upper arms, rod, etc., but did not see any. There is some play with the tie rod. Two other things I saw are a missing bolt from the axle to the differential and "grease" like residue on the shocks, not leaking but like old grease. Could this be a sign of bad shock. I don't see any codes. Any thoughts? |
12-21-2023, 07:02 PM | #2 |
Drives: Chevrolet Camaro SS Join Date: Oct 2023
Take pictures if you don't mind, it would be helpful.
01-07-2024, 08:59 PM | #3 |
Drives: 2022 1ss/1le Join Date: Mar 2022
I have full mag ride set with camber plates for sale if you need it. has 8k miles and off a 22 ss/1le
id sell just the rears as well. |
01-07-2024, 10:06 PM | #4 | |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Caveat: I'm not a mechanic and this isn't a proper diagnosis, you should go see a real mechanic or a service department to be certain, but I can say that several members have had proven MRC failures with similar symptoms after a similar amount of time (assuming your mileage is typical).
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
