#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Suspension | Brakes | Chassis
Old 02-07-2024, 04:56 PM   #1
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Drives: 2020 2SS - A10, NPP, MRC, CAI
Changing Brake Line Gotchas?
I had some credit at Phastek and decided to get some upgraded RST Stainless Steel Brake Lines for my 2SS (non-1LE), I figured it would be the perfect time to put them on since I was going to replace my brake fluid with Castrol SRF.
Any gotchas on changing the brake lines and/or bleeding the brakes/changing fluid? I've done brake fluid replacements on others car just not this one.
Any advice or insight would be appreciated.
Thanks!
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
2SS Capt is online now   Reply With Quote
Old 02-07-2024, 05:01 PM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Never done it myself but will soon, here is what my friend told me to do.
"Brake lines very easy, just do the lines in the correct order to avoid running the brake fluid too low.
Detach from caliper and tuck the stock line high enough that it doesn't drip, install new line on caliper side, then take off old line from body side and install new line. Top off brake fluid right away if needed. Just trying to minimize risk of running air into ABS pump"
Christian1LE is offline   Reply With Quote
Old 02-07-2024, 05:08 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
when i had mine installed the shop said new camaro was a bitch to do lol just to do it like 4 times and something about the master cylinder was tricky to get all of the old fluid out
now i just do a drain and refill every year so its not as bad ive been told
kropscamaro16 is offline   Reply With Quote
Old 02-07-2024, 09:56 PM   #4
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
Might check out this note.
https://www.camaro6.com/forums/showthread.php?t=609473
Eric10905 is offline   Reply With Quote
Old 02-07-2024, 10:45 PM   #5
2SS Capt
2SS Capt's Avatar
Originally Posted by Eric10905 View Post
WOW, thank you!
Old 02-08-2024, 12:05 PM   #6
Eric10905
No worries. Line replacement and bleeding is easy. If you don't already have something, I recommend a bleeding tool such as Motive. I use the dry method since I bleed and change fluid a lot for track use. There's some step by steps on here somewhere as well.
Old 02-09-2024, 01:23 AM   #7
2SS Capt
2SS Capt's Avatar
Would you please elaborate on what "Motive" is? I bought a check valve bleeding bottle from Amazon, but my Brother will be here to help (another "Car Guy" of 45+ years) but I just don't want to screw this up... The thread about mounting the lines correctly (so they have full lock-to-lock motion) was very eye opening, it is just those kinds of things that come to light that one might not think about...
This is the check-valve bleeder I bought on Amazon... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have no problem returning it or getting something else if there is something better or more appropriate...
Thank you for everyone who has provided input and suggestions, it is very much appreciated! I always try to help where I can and I appreciate the help when needed or requested, thank you!
Old 02-09-2024, 05:27 AM   #8
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
This is the Motive bleeder he meant: https://www.amazon.com/gp/product/B000TK9FE8. It has a pump and a pressure gauge, which makes brake fluid changes much easier, no more guesswork about always having enough pressure in the lines.
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
Old 02-09-2024, 06:58 AM   #9
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
The Motive pressure bleeder is one of the best tools I bought. Easy one man bleeding. But don't put the fluid in the Motive. Just keep adding to the reservoir. Don't let it run dry. Keep checking the level.
You may need to do an ABS solenoid bleed procedure. There are some scan tools on Amazon that can do this.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
cdb95z28 is offline   Reply With Quote
Old 02-09-2024, 12:09 PM   #10
Eric10905
^ yep, these guys answered and agree with both. OP, unfamiliar with the check valve bleeder you linked. It may work fine, but I've never used one myself so can't say. I used the Motive bleeder (dry) since I bleed a lot for track reasons.
The thread linked below is pretty detailed, albeit, I have never reviewed it step-step. Note the change in order by Carguy55.
https://www.camaro6.com/forums/showt...ighlight=brake
It must be age, as now I am remembering more. Use a torque wrench on the bleeders.
https://www.camaro6.com/forums/showthread.php?t=614932
Old 02-09-2024, 12:36 PM   #11
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
When I did my lines I didn't realize the ABS pump might need a scan tool to bleed, but using the Motive pressure bleeder, it went fine. I was doing some other work so I just let it ALL drain out, and still had no issues. I wouldn't do it that way again though.
DaveC113 is offline   Reply With Quote
Old 02-09-2024, 02:01 PM   #12
2SS Capt
2SS Capt's Avatar
Ok, I just ordered the power bleeder, what size are the bleeders on the calipers and what is their torque?
Old 02-09-2024, 03:02 PM   #13
atx_traveler
Drives: blue velvet
Get a set of these flare nut wrenches: https://www.lowes.com/pd/CRAFTSMAN-5...Set/1000600333
I didn't worry too much about torque; I simply set the wrench back to its starting position and called it good.
atx_traveler is offline   Reply With Quote
Old 02-11-2024, 01:11 PM   #14
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
My experience was to attach it to the steel line before you attach it to the caliper. I found it can be a pain to get the threads lined up if the line is not loose. Once attached to the frame then let some some fluid drip out and attach to the caliper. When I remove the OEM line from the caliper I use a piece of inter tube tire rubber and a small clap to keep the line from leak fluid while I remove it from the steel line. I use the Motive bleeder and have never had an issue but I have heard of people having issues with the antilock and having to go through the GM bleed procedure with a scan tool.
dpevans is offline   Reply With Quote
