![]() ![]() ![]() ![]() Drives: 2010 2LT/RS Black/IOM Join Date: Feb 2011
Switchblade Key Fob Damaged by Repair Shop. Now what?
My air condenser was replaced by a repair shop that I have gone to on numerous occasions. The garage was nice enough to drive my car back to my house for me, and put my key fob in the mailbox like I asked them to.
But when I woke up this afternoon to get my keys out of the mailbox, they were gunked up with grease which I tried to wipe away, only to find that there was a big hole in the trunk button that I know wasn't there previously. As you all probably remember there was a recall on these and I never went and got the new ones because I like to switch blade fob better. So should I just say nothing or should I let them know about the damage, because chances are I'm just going to have to go to the dealership and get the replacement key fobs anyway.
ZL1 Factory Reproduction Wheels, Airaid CAI, MRT V 2.0 Axle Back Installed by PIE Customs, Painted IOM Rally Stripes, Bowties by Danny Taylor Louisville KY, IOM Engine Cover and Fusebox Cover by River City Creations and Lighting San Antonio TX.
#2 | |
Life is short, drive it like you stole it! ![]() |
#3 | |
Edit: YouTube has just about everything. Looks like the original fobs are a p.i t.a. to get open however. https://keyless-remotes.com/chevrole...kaAp8aEALw_wcB
Boosted Moderator
I have two of these but they are spoken for...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
There is just a little roll pin that holds the key on. You don't even have to get them cut. Just swap your existing key into the new fob.
FYI, in my experience the aftermarket fobs don't last as long as the factory ones, but that is just something you have to live with. I had a fob fail the same way yours did and another on the way out.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
That fob is wore out and is due for replacing anyway. That would have happened soon anyway so I wouldn't worry about it. When my fobs wore out, I replaced them with these https://www.ebay.com/itm/295814531489. And yes the factory fobs was such a pain to get open. I think I ended up taking a pair of needle nose pliers and breaking off the back because over the years the fobs got so full of gunk they wouldn't separate.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Look up: Batteries Plus Bulbs. There are several near me so see if you have one.
They stocked my '10 SS key fob plus the equipment to program it. I bought 2 since I only had to pay for one set up. In stock, inexpensive and in and out of their store in less than an hour.
#8 |
![]() ![]() ![]() Drives: 2010 2LT/RS Join Date: Mar 2015
Doesn't the dealership still offer these switchblade fobs even if you decline the new ones they provide for the recall? That's what I did about 7 years ago. Unless these are discontinued as well??
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
#9 | |
Big John
Drives: Wife 2013 Camaro 2SSRS / ME? Join Date: Mar 2012
https://www.ebay.com/itm/11444883802...mis&media=COPY |
#10 |
They do but depending on your dealer, they are very expensive.
