Old 01-14-2012, 04:15 PM   #1
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
Heated seat turns on then off
Well today I took the camaro out n went to turn the heated seat on and the light went on but then it shuts off a minute or two later,,,,,what could be the problem?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 01-14-2012, 04:22 PM   #2
SC2150
The seat heaters are powered through a relay that kicks out if there is to much draw to prevent a fire, etc. Sounds like a failure with the heating element and you are seeing the relay kick out.
Old 01-14-2012, 04:26 PM   #3
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Well that should be covered under warrantee right? Will they check if I have a tune when they look at that?
Old 01-14-2012, 04:27 PM   #4
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Where is the heating element ?
Old 01-14-2012, 06:11 PM   #5
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Old 01-14-2012, 08:11 PM   #6
Eric Baker
Drives: Black/Black 2SS/RS 6M
They have no reason to check for a tune since it's not powertrain related. It should be covered no problem.
The heating elements are in the seats. One on the bottom and one on the back of each front seat.
Eric Baker is offline   Reply With Quote
Old 01-14-2012, 11:43 PM   #7
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Okk thanks guys
Squeak from drivers seat or console? klondike Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 23 02-28-2018 01:00 AM
Convert cloth to leather upholstery coreyk Camaro DIY & HOW-TO instructions & discussions 42 11-17-2014 09:55 PM
Old man winter's coming: heated and/or massage seat kit sale @ PFYC - PartsForYourCar PFYC Interior Parts & Accessories 0 10-11-2011 10:30 AM
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 05:00 PM
Heated seat switches F2000Doc 5th Gen Camaro SS LS LT General Discussions 48 09-09-2009 06:58 PM
