07-04-2018, 07:37 PM | #1 |
Drives: 2012 SS Join Date: Feb 2016
Wideband A/F guage
I was wondering that since my rear O2s are turned off, could I use one of t the bungs for a wideband O2 sensor, or is it too far down stream. I do not have cats at the moment. Thanks in advance.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
07-04-2018, 08:04 PM | #2 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Most widebands will tell you in the installation instructions where they prefer to be placed. Like 18-30 inches downstream for example. I think that second bung may be too far. I had one welded in a few inches before my first o2 sensor inside the header collector, and slightly offset so it didn't block the airflow of the stock one.
It only cost me $40 for the weld job.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
09-30-2019, 12:28 AM | #3 |
Drives: 2013 Camaro SS Join Date: Feb 2017
I have the same question about using the o2 sensor location for the wideband. I'm also catless with long tube headers.
09-30-2019, 01:43 AM | #4 | |
Sent from my Pixel 2 using Tapatalk
2010 Camaro 2SS
2018 Charger GT+ 2005 Cavailer LS S/C - Sold '87 HD FXRT - Wrecked pending repair |
09-30-2019, 03:50 AM | #5 | |
09-30-2019, 06:54 AM | #6 |
Just follow the directions of the manufacturer. You do want to put it in a place where all the gasses from the primaries converge, not just in a single primary. Make sure the sensor is clocked in such a way as to allow condensation from start up to travel away from the sensor, not pool into the sensor.
09-30-2019, 08:44 AM | #7 |
The rear O2 sensor bungs are fine and make a great spot for your wideband. If you do decide to add another bung just don't place it on the bottom half the pipe. Water can collect on the bottom and you don't want the sensor facing down if you bottom out.
10-01-2019, 10:53 PM | #8 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
I would not place the sensor downstream it needs accurate temperatures coming Cleanly from the exhaust to provide accurate data, not to mention the potential damage if the cat comes internally apart or the cat is not 100% sealed.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
10-02-2019, 04:28 AM | #9 |
10-02-2019, 08:34 AM | #10 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
I look at this a couple different ways. The safest thing to do is follow the manufacturer's suggested location in terms of distance downstream. That's what I did. I put mine in the header collector, in front of the HFCs. Since you don't have cats, I see no problem with the sensor being a little bit further back to take advantage of the existing bung(s).
If you don't have a wideband, the dyno tuner will just put the sensor in the end of your tailpipe anyway. That is a lot further back than the rear O2 bung.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
10-02-2019, 08:30 PM | #11 |
10-03-2019, 08:54 AM | #12 | |
Ted.
www.jannettyracing.com
10-04-2019, 01:54 AM | #13 |
RIGHT ON POINT!
10-04-2019, 06:52 AM | #14 |
That's strange, if all this is true, why do dyno's have a wideband for tuning that fits in the tail pipe? 4 wire sensors are heated so that parts irrelevant. With the exception being the time delay from the engine output until it reads on the gauge, I dont see a disadvantage for installing a few inches farther back. Maybe if you're using it for data logging you might want the fastest response possible.
