01-21-2014, 04:06 PM | #1 |
Drives: '02 Trailblazer, '12 Camaro 2SS/RS Join Date: Jun 2012
Flex 3401 VRG question
So looking at the Flex it looks like it comes with a 6" backing plate, correct? They sell a changeable backing plate system has both a 4 and 6 plate (($50). then there is just a 4 plate for $30.
I like to option of having a smaller plate for small pads. So does the "system" allow for quicker changes of the plates? Or will I just end up with two 6" plates, spend more, and still have to go through the same process to switch plates?
01-21-2014, 04:27 PM | #2 |
Drives: red Join Date: Jul 2012
If you have a LC kit in mind then a single allen screw is removed to go from 4" to 6".
01-21-2014, 04:35 PM | #3 |
Is that system different/easier than just buying the 4 3/8 plate and swapping between that and the stock larger backing plate? If so, it seems like it would be a good option for versatility.
It would be nice if I could still sue some of the pads I have from my 7424XP as well as some of the smaller 4" pads.
01-21-2014, 04:43 PM | #4 |
My partner just had the kit from LC. It did break a plate once but they quickly replaced it. The 3401 was also refurbished once by Flex without charge.
01-21-2014, 05:11 PM | #5 |
cool. do you know if this system actually makes it easier to swap the plates out? Or is it just the same if I use the stock plate and buy the smaller one too?
01-21-2014, 05:25 PM | #6 |
I can only speak about the 3 pc kit which made swaps easier.
01-23-2014, 09:43 AM | #7 |
Drives: 2010 Mazdaspeed 3 Join Date: Mar 2012
Yes this kit does make it easier because you are not changing the gear mechanism. It is not a HUGE difference, but it is noticeable.
