07-05-2018, 11:15 PM | #1 |
Drives: 2017 Camaro 2.0 RS Join Date: Jun 2017
Well this is not good.
Go out to my Camaro, wont start, details, 3900 miles 13 months old, ran perfect until now? Turbo 4, Auto.
When I went to start, it does all these snapping noises, says battery saver is on and then says battery low. How can a battery go bad at only 3900 miles, I guess I am stuck until tomorrow when I can call the dealer, and no way to get to work either, bummer. Flaps |
07-05-2018, 11:31 PM | #2 |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
Loose terminal or ground... happened to me once.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
07-05-2018, 11:36 PM | #3 |
How to check
07-05-2018, 11:46 PM | #4 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Don't believe it, do a search ...many batteries discharge/ go bad in the six GEN Camaro world… Nobody has a real good answer as to why.....
07-05-2018, 11:55 PM | #5 |
Checked it
Connections are tight, so I guess its not that, weird battery set up compared to what I am used to.
Guess the dealer can tow it tomorrow and hopefully figure it out. Flaps |
07-06-2018, 12:00 AM | #6 |
Drives: '18 SS 1LE Join Date: Apr 2011
The snapping sounds you heard are probably from arcing and sparking as something was shorting itself to ground. The battery terminals are as good a place to start as any. Make sure they are tight, the dust boots are in place and there's no exposed wiring. I'd also look for loose cabling under the hood, maybe a frayed cable with some exposed conductor, or melted insulation?
Make sure there are no cables near moving parts, or anything that gets hot, like the headers or your turbo. Also look for black scorch marks. If you find those, your probably going to find your failed cable near by. Either way, your best bet is to get it towed to your dealer and not start it up until it's fixed. Good luck. |
07-06-2018, 12:36 AM | #7 |
Drives: 2016 2SS Convertible Join Date: May 2012
Unfortunately even new car batteries occasionally fail without warning. A friend had one fail in their Camaro after 6 months. The dealer replaced it under warranty.
The clicking sounds you hear could be from the starter relay. Your battery has enough juice to energize the starter relay but not enough to start the car. If it is just the starter relay clicking then it isn't a dangerous condition like a short circuit and shouldn't damage the car. |
07-06-2018, 07:33 AM | #8 |
Drives: Tesla M3 LR-AWD [Former 1SS owner] Join Date: Jan 2018
90% probability it's a bad battery. Happens.
07-06-2018, 07:38 AM | #9 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
My Honda Accord had a bad battery that died within 2 weeks of my buying the car; the replacement battery died 2 years later.
07-06-2018, 07:49 AM | #10 |
BTW, did you check to make sure you didn't accidentally leave something on?
07-06-2018, 08:02 AM | #11 |
I will say this again. They will either find that the battery is not a problem or they will replace it. And then a year or two down the road it might happen again. Many of us have had this happen. There's something in the Camaro system that drains the battery through no fault of your own. I don't believe GM is giving us a good answer on this. I've gone through two batteries in my Camaro and they can find no fault found. I now have a quick disconnect switch on the battery so I can disconnect it if it's going to sit longer than two or three days…I'm actually going to get rid of the car pretty soon because of this problem.
07-06-2018, 09:06 AM | #12 |
Just came back from a 2 week vacation and it fired right up. We'll see in a year or so from now. The 1SS does have less gadgetry and / or maybe the 2018s are less prone?
07-06-2018, 09:08 AM | #13 |
Mine fired up after being 13 weeks completely down with no disconnect. Six months later, it died after two days…...This has been going on for years, and no one has come up with a good answer yet.
07-06-2018, 11:01 AM | #14 |
Drives: 2019 CLA 450 Mercedes Join Date: May 2016
If you have OnStar, just call them. They will give you a jump.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
Thread Tools | |
