12-17-2011, 03:08 PM | #1 |
how to figure out build date
I have a 2010 the last 4 of the vin are 8222. I know this was delivered in 2009. I still have chicklets so i know it was early but i'd like to know how early in production is was. can anyone help?
12-17-2011, 03:19 PM | #2 |
Drives: 2011 2SS/RS LS3/6M Litho#190 Join Date: May 2010
If you post,or PM me,the last 8 digits of your VIN I can pull up the build sheet which will include the build date
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned Proud Litho owner #190 - Homecoming Litho #120 '15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA |
12-17-2011, 03:21 PM | #3 |
They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
There is a sticker in the engine bay on the frame.....
Hey MS3DALE, could you do that for me? I'd love to see my build sheet. I know the build date already... my last 8 are B9171101.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
12-17-2011, 03:32 PM | #4 | |
VIN: 2G1FB1ED4B9171101 Model: 1EF37-2011 CAMARO 1LT COUPE Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes Order Type: 70 - RETAIL - STOCK Field Actions: 0 Open Vehicle Build Model: 1EF37-2011 CAMARO 1LT COUPE Order Number: PHPJJ5 Build Date: 03/10/2011 Build Plant: 9- Option Codes*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker. 01S - SEAT TRIM MED TITANIUM 1AB - DR PANEL TRIM JET BLACK 1LT - BASE EQUIPMENT PACKAGE 1SZ - OPTION PACKAGE DISCOUNT 3BI - MOLDING I/P JET BLACK 4AV - INTERIOR TRIM JET BLACK W/ TITANIUM 6Y4 - TIRE & WHEEL SPARE-DELETE AE4 - SEATS, FRONT SPORT BUCKET, INCLUDES ADJUSTABLE HEAD RESTRAINTS AND FOLDING REAR SEAT WITH TRUNK PASS-THROUGH AEF - WINDOW POWER OPERATED, PASSENGER, EXPRESS UP/DOWN AFD - GRAY AG5 - SEAT ADJUSTER, FRONT PASSENGER 2-WAY MANUAL (FORE/ALT) WITH POWER RECLINER AL0 - SENOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR AMM - SEAT ADJUSTER, DRIVER, 6-WAY POWER (FORE/AFT, UP/DOWN) WITH POWER RECLINER AT8 - RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING ATG - REMOTE KEYLESS ENTRY AUD - ID COUPE CHANGES WITH SOP CONV AX2 - KEY COMMON, VEHICULAR UNIQUE AXG - WINDOW POWER OPERATED-EXPRESS DRIVER UP/DOWN AXJ - VEHICLE TYPE PASSENGER CAR AY0 - CURTAIN SIDE IMPACT AIRBAGS B34 - CARPETED FLOOR MATS, FRONT B36 - COVERING FLOOR MAT, LUGG COMPT. B56 - MOLDING ROCKER BODY COLOR BD8 - MOLDING BODY-COLOR ROOF DITCH C67 - AIR CONDITIONING D75 - DOOR HANDLES BODY COLOR D80 - REAR SPOILER DBW - MIRROR, INSIDE REARVIEW MANUAL DAY/NIGHT DCP - 1 YR ONSTAR DIRECTIONS W/ AUTOMATIC CRASH RESPONSE & TURN-BY-TURN NAVIGATION (ASK DEALER ABOUT GEOGRAPHIC COVERAGE) DG7 - MIRRORS, OUTSIDE POWER-ADJUSTED BODY-COLOR EF7 - COUNTRY UNITED STATES OF AMERICA (USA) EMG - TRIM SEAT CLOTH, SPEED FCQ - TRIM DOOR CLOTH, MONTILE FE2 - SUSPENSION SYSTEM-SPORT FE9 - 50-STATE EMISSIONS FHO - VEHICLE FUEL GASOLINE E10 GAP - IMPERIAL BLUE METALLIC GW6 - 3.27 REAR AXLE RATIO JL9 - BRAKES- 4 WHEEL ANTILOCK, 4 WHEEL DISC KG4 - ALTERNATOR, 150 AMPS KI2 - SHIFT KNOB, URETHANE LHD - VEHICLE DRIVE LEFT HAND DRIVE LLT - ENGINE, 3.6L V6 SIDI M97 - SHIFTER INTERLOCK BRAKE, TRANS MX0 - TRANSMISSION, 6-SPEED AUTOMATIC W/ TAP SHIFT MYB - TRANSMISSION, 6-SPEED AUTOMATIC N10 - DUAL EXHAUST SYSTEM N41 - STEERING, POWER, VARIABLE RATIO N45 - STEERING WHEEL,3-SPOKE,URETHANE NT7 - FEDERAL EMISSIONS SYSTEM NZK - CONTROL STEERING WHEEL, CRUISE CONTROL SWITCH OSH - OSHAWA PLANT CODE P43 - TIRE SEALANT AND INFLATOR KIT Q9J - WHEELS 20" POLISHED ALUMINUM QOO - TIRES P25/45R20 FRONT AND P275/40R20 REAR, SUMMER R9N - PROCESSING CODE-SEAT SBF - RESTRAINT SEAT BELT SGC - SPARE TIRE & WHEEL NOT DESIRE TIRE SEALANT & INFLATOR KIT IN PLACE OF SPARE TIRE SLM - STOCK ORDERS T3N - LAMP SYSTEM DAYTIME RUNNING SEPARATE CAVITY T4F - HEADLAMPS HIGH INTENSITY T83 - HEADLAMPS CONTROL AUTOMATIC ON-OFF TB8 - HEADLAMPS CONTROL RH RULE OF THE ROAD U2K - XM RADIO - SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUS/XM AFTER 90 DAYS U77 - ANTENNA, INTEGRAL REAR WINDOW UDC - DISPLAY INSTRUMENT DRIVER INFO ENHANCED (ONE COLOR GRAPHIC) UE1 - * 6 MONTHS ONSTAR DIRECTIONS & CONNECTIONS WITH AUTOMATIC CRASH RESPONSE AND TURN-BY-TURN NAVIGATION (ASK DEALER ABOUT GEOGRAPHIC COVERAGE) UJ6 - TIRE PRESSURE MONITORING SYSTEM UMN - SPEEDOMETER INST, MILES & KILO, MILES ODOMETER UQ3 - AUDIO SYSTEM 6-SPEAKER SYSTEM UTJ - THEFT DETERRENT ELECTRICAL UNAUTHORIZED ENTRY UYE - AM/FM STEREO, CD-ROM, MUSIC NAVIGATOR WITH ETR, GID(GRAPHIC INFO DISPLAY), W/AUX JACK V8D - VEHICLE STATEMENT US VRG - VAA/COMPONENT REL ****PIT VRH - VAA/COMPONENT REL STEERING COLUMN VRK - VAA/COMPONENT REL ROOF TRIM VRL - VAA/COMPONENT REL FRONT HORIZONTAL SUSPENSION VRM - VAA/COMPONENT REL FRONT VERTICAL SUSPENSION VRN - VAA/COMPONENT REL REAR SUSPENSION VRR - VAA/COMPONENT REL TIRES & WHEELS WRS - RS PACKAGE: *20"X 8" FRONT AND 20"X 9" REAR FLANGELESS, PAINTED ALUMINUM WHEELS WITH MIDNIGHT SILVER FINISH *BODY-COLOR ROOF DITCH MOLDING *HEADLAMPS HIGH INTENSITY DISCHARGE WITH HALO RING (DAYTIME RUNNING LAMPS REPLACE FOG LAMPS) *REAR SPOILER *RS UNIQUE TAIL LAMPS WZI - CONTROL STEERING WHEEL, TRANSMISSION, REDUNDANT CONTROL XL7 - FREQUENCIES RATING 315 MHZ, LONG DISTANCE XR5 - FILTER POLLEN
12-17-2011, 04:07 PM | #5 |
mine was built on 7/22/09, any idea when the first ones rolled off the line? anyone?
12-17-2011, 04:25 PM | #6 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
First day of production was March 16, 2009. Mine came off the line 7/24/2009.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
12-17-2011, 04:29 PM | #7 |
So that build sheet says I have the midnight silver rims.
Yet my rims are the 20" polished aluminum SS rims. Does that mean I should have an extra set of wheels?
12-17-2011, 04:37 PM | #8 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Look again Q9J Polished.
12-17-2011, 04:38 PM | #9 |
Right.... but since I paid for the RS rims shouldn't I get them too?
12-17-2011, 05:11 PM | #10 |
No,The polished wheels were optional,and replaced the Midnight Silver wheels that were part of the RS package.
12-18-2011, 12:22 AM | #11 |
Drives: 2012 Camaro 2SS 45th Anniversary Ed Join Date: Oct 2011
Thanks a bunch for the info. I am a noob on these things.
What does the following mean? Branded Title: No Found out this one: Vehicle title branding is the use of a permanent designation on a vehicle's title, registration or permit documents to indicate that a vehicle has been written off due to collision, fire or flood damage or has been sold for scrap. Warranty Block: No PDI Status: Yes Order Type: 81 - DEALER USED CAR (CVMS USE)
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
12-18-2011, 04:24 PM | #12 |
ustate C5 member
open hood- stand in front of rt headlamp- look down into engine compartment- you will see a diagonal brace at rt lower part- there is a decal ( White with white background- black letters). It shows day date and hour of production.
12-18-2011, 05:55 PM | #13 |
Yes,Thats date the front suspension/engine cradle was assembled at the Martinrea plant in Ajax,ON.,Its usually within a day or two of the build date,but not always the vehicles actual build date.
12-18-2011, 09:57 PM | #14 |
Drives: 2010 1SS IBM L99 Join Date: Apr 2009
Similar Threads | ||||
Must post picture of a Chevy to win. | "prima"Donna | Off-topic Discussions | 74976 | 09-13-2013 11:33 PM |
build date ? | rhumberger | 5th Gen Camaro SS LS LT General Discussions | 0 | 09-06-2010 09:33 AM |
ATTN Dealers or Oshawa plant workes: Trying to confirm my build date! | Bluestreak 2010 | Camaro Price | Ordering | Tracking | Dealers Discussions | 7 | 08-26-2010 07:13 PM |
Build Date Obtained | Rickscamero | Camaro Price | Ordering | Tracking | Dealers Discussions | 0 | 07-23-2009 02:17 PM |
"Camaro on the way" but no build date?! | drtwo | Camaro Price | Ordering | Tracking | Dealers Discussions | 10 | 07-22-2009 06:33 PM |
