11-26-2017, 05:52 PM | #1 |
JEGS SSR Star Wheels
http://www.jegs.com/i/JEGS-Performan...80291/10002/-1
Does anyone have experience with these? Will they fit? What do they weigh? It has the same backspacing as the race stars but the offset is different by 1.4. Will that cause it to hit the Brembos?
12.3 @113MPH - Full Bolt-Ons w/ Nitto 555r on 18" wheel
11-30-2017, 10:49 PM | #2 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I'm a RS dealer, and have experience Welds too. Based on my experience, those wheels might fit. You want to look at the backspacing (1.75), the bolt pattern (5x4.75) and the hub bore (120 I think is right I did not check it just going off memory).
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
12-01-2017, 12:34 AM | #3 |
Drives: 13' 1LE Join Date: Apr 2012
Thats cheap!!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
12-02-2017, 06:24 PM | #4 |
I think the red Camaro has those rims!!??
13' 1LE
12-02-2017, 07:32 PM | #5 |
Literally just watched that video haha. I ended up going with race stars. But if any one figures it out it would be good info to know. They are real cheap.
Sent from my Pixel using Tapatalk
12-02-2017, 10:01 PM | #6 |
He's running billet specialities.
12-03-2017, 03:51 AM | #7 |
Ok nice..those wheels were too sweet to be that cheap on a big setup like that!
13' 1LE
12-05-2017, 08:47 AM | #8 |
Drives: 2015 Camaro 2ss Join Date: Feb 2017
I’m running those up front in 17s
12-05-2017, 10:26 AM | #9 |
Damn wish I had known they'd fit before I pulled the trigger on the race stars. What do they weigh?
12-05-2017, 10:48 AM | #10 |
I did weight them I forgot the exact number but I wanna say right around 21lbs with a 27.5” Hoosier
12-05-2017, 10:57 AM | #11 | |
12-05-2017, 11:09 AM | #12 |
No way it’s a 27.5x 4.5 it’s a skinny Hoosier tire. I only had to cut the outer ears off brake pad and it clears the caliper with no problem.
12-05-2017, 12:11 PM | #13 | |
Drives: 2013 VR 2SS w RS 1LE Join Date: Jul 2013
I just got some Weld S71 for front runners. I currently have some black gorilla lugs on my car, but wanted to know if you knew the right part number for some black gorilla lugs that work with the welds. |
12-05-2017, 08:23 PM | #14 |
Writer
I don't recall the PN number for the Gorilla lugs offhand, I got them from another thread on here a few years back. Phastek might carry them?
Steve just to clarify, you had to cut off the roller skates but they otherwise just bolted righ t up?
PROJECT HEAVY CHEVY
