#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
BeckyD @ James Martin Chevy
Old 04-01-2019, 07:09 AM   #1
samjlee27
samjlee27's Avatar
Drives: Summit White 2018 Camaro 1SS M6
Issues after installing cold air intake
I've installed K&N Cold air intake (63-3092) and since then I've noticed several issues pop up that were not there prior to install.
1.) Really bad rev hang, if I rev the engine in first or reverse it will hold at like 2-3k RPM's. If I rev it up while clutched in or in neutral, the revs will drop very very slowly.
2.) Power loss, I've noticed that the car feels far more sluggish and this was evident when I did a 40 roll with a bud's Focus ST and I was neck to neck with him rather than flying past him like I used to.
3.) Radiator Fan comes on randomly at full speed every once in awhile.
Any ideas as to a possible fix for these issues?
samjlee27 is offline   Reply With Quote
Old 04-01-2019, 07:47 AM   #2
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
I have not installed a cold air intake onto a fuel injected engine, so I do not have any first hand experience with this.
However, with your symptoms it sounds like you have a vacuum leak (false air) entering the system like an intake gasket leak or a vacuum hose not connected properly. This would typically cause the revs to hang.
Otherwise, you will need a tune. But others may be able to chime in here if that is neccesary.
mrgoodbytes is offline   Reply With Quote
Old 04-01-2019, 07:51 AM   #3
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
did you get any codes? i've seen where people didn't install it correctly like on the throttle body or MAF sensor, recheck and go from there.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 04-01-2019, 07:56 AM   #4
Juiced1
Drives: 2012 2SS CAMARO 45th
I would check for leaks first. Make sure all your fittings are secure and tight.
Juiced1 is offline   Reply With Quote
Old 04-01-2019, 10:29 AM   #5
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Vacuum leak or your filter is over oiled.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 04-01-2019, 11:31 AM   #6
samjlee27
samjlee27's Avatar
No codes, have unplugged and replugged MAF sensor multiple times. Will check again for any leaks
Old 04-02-2019, 07:53 AM   #7
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
Did you disconnect the negative battery terminal before you unplugged the MAF sensor?
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
TJay74 is offline   Reply With Quote
Old 04-02-2019, 08:22 AM   #8
samjlee27
samjlee27's Avatar
I did not, thinking back this might of been my dumb mistake.
Old 04-02-2019, 09:01 AM   #9
Umbriel
Drives: 2016 Camaro SS
I highly doubt it is that I didn't unplug mine either, didn't see any reason to. Sounds like you have a vacuum leak somewhere and you are getting unmetered air into the engine.
Umbriel is offline   Reply With Quote
Old 04-02-2019, 01:22 PM   #10
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
get a tune a cold air intake isnt going to do much alone
kropscamaro16 is offline   Reply With Quote
Old 04-02-2019, 02:33 PM   #11
TJay74
Actually it can, on the 6th gen cars there are several modules that stay online and active. The MAF can trip errors if unplugged while the ECM still has power.
I never used to pull the battery, but now I do on the 6th gen due to random errors when sensors are unplugged while the battery is still connected.
Old 04-02-2019, 02:34 PM   #12
F1FTY
Drives: 2018 ZL1
Check your throttle body bolts/gasket.
F1FTY is offline   Reply With Quote
Old 04-03-2019, 07:16 AM   #13
samjlee27
samjlee27's Avatar
@Tjay74 how do I check if it is the MAF sensor? And if so, how can I resolve it? I have checked for any leaks, tightened all my bolts but the problem still persists
Old 04-03-2019, 08:39 PM   #14
TJay74
Cant really check it unless you have something like HP Tuners, otherwise you can have the auto parts store check for codes.
Only other option is to put the OEM air kit back into the car.
